Trouble with new (to me) PT
Old 19 Sep 2012, 04:46 pm
Default Trouble with new (to me) PT
I just picked up a 2005 PT Cruiser this weekend. After some early trouble that I think is worked out, I have a check engine light come on going to work. The car is running good. No missing or coughing.
A check of codes using the dash/key method shows me P0420 (Catalyst System Low Efficiency from this website) and P0513 (nothing showing up on this site). Autozone's code reader found the P0420 but not the P0513. Their "fixes" are
1.) Catalytic converter defective.
2.) Engine misfire or running condition
3.) large vacuum leak
4.) engine oil leakage into exhaust-valve guide seals, piston rings (I think meaning engine overhaul.
I didn't detect anything close to a miss (doing 60 on the interstate) or do I detect any burning oil.
What might this be? I have a 1 month/1000 mile warenty from the seller, but I would like to take this to them with a little knowledge of what might be going on.
2003 Nissan Altima (Son's)
2011 Smart For2
2005 Chrysler PT Cruiser Convertible (Toad)
2006 Saturn Vue (Daughter's)
1999 Holiday Rambler Motorhome (Retirement home someday!)
Old 19 Sep 2012, 06:54 pm
Ray_Dockrey's Avatar
Default Re: Trouble with new (to me) PT
This thread is going on at the same time. I think you will find your answers there.
P0420
Old 19 Sep 2012, 07:12 pm
Vlefaive's Avatar
Did you try CTRL-ALT-DELETE?
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 19 Sep 2012, 07:40 pm
P0513 Invalid SKIM Key
SKIM = Sentry Key Immobilizer
In other words, the security system didn't like the key you were using.
Old 20 Sep 2012, 05:58 am
I hope I dont have trouble first getting to work today and then back to the car lot this afternoon. I had tons of trouble with it yesterday. Almost didn't get home from church. I think the key is going to be a big issue!
Now it had numerous trouble codes.
2011 Smart For2
Old 20 Sep 2012, 10:33 am
When you start it, does it crank fast? A low battery produces all sorts of gremlins in a PT...
Old 20 Sep 2012, 05:00 pm
When all is good (like all day today) it starts fast. Starter is turning good. The battery has a 9/10 sticker on it - don't know if that means it was bought then or a build date. The car is giving about 6 different codes when I pull them up on the dash. None of which is the P0420 I had yesterday.
Is there any way to turn off the key system?
2011 Smart For2
Old 20 Sep 2012, 06:00 pm
Maybe someone else can understand what you trying to turn off but I'm not sure what it is. Sounds like you don't want to be able to use your key anymore.
Old 20 Sep 2012, 06:56 pm
I was just wondering if there was a way to turn off the security system. I would just like to have the car operate at the turn of the key and not have to worry about the chip.
2011 Smart For2
Old 20 Sep 2012, 07:28 pm
The Owners manual tells you how to override/disable the alarm system itself but you'll still need the "chipped? key to start the engine. Says nothing about doing away with that part of it.
PT Trouble hotcarl Tech & Performance Forum 6 16 Jul 2007 02:21 pm
03 PT trouble Gina General PT Cruiser Discussions 4 22 Feb 2007 02:06 pm
HELP TROUBLE!!!! PTNeo Tech & Performance Forum 4 16 Jul 2004 01:22 pm
Your all in big trouble : ) Punch General PT Cruiser Discussions 1 26 Oct 2003 04:03 pm
trouble !! bobs turbo pt General Turbo Discussions 7 01 Jul 2003 01:41 pm
