How To Check Rear Suspension?
Old 21 Sep 2012, 01:52 pm
Default How To Check Rear Suspension?
I have a clunk coming from the rear of my 2006 PT whenever I go over some rough spots in the road.
I have a little experience with the front suspension components but absolutely none with the rear.
Can anyone here tell me what I should be checking/looking for?
Any input is always appreciated, thanks
Old 21 Sep 2012, 01:55 pm
Default Re: How To Check Rear Suspension?
Its most likely your wattslink bellcrank :-)
Old 21 Sep 2012, 01:58 pm
Aw the accursed never seen by me before, wattslink bellcrank!
Old 21 Sep 2012, 04:07 pm
Its in the center of the rear axle and both control arms run to it. looks like of like a dog bone with 3 bolts in it, when the center bolt becomes worn, it causes the car to get almost like a dull gong noise when you hit a bump ;-)
Old 21 Sep 2012, 06:21 pm
Thanks for the help
The center bolt or the center bushing?
How do I check it for wear?
Old 21 Sep 2012, 06:26 pm
rcktpwrd's Avatar
Cool Re: How To Check Rear Suspension?
Lots of info here: Watts-Link or Bellcrank Replacement
Joel
www.rcktpwrd.com
Old 21 Sep 2012, 06:28 pm
Bolt goes through the bushing, I'm gonna guess there should be no play in it?
Old 21 Sep 2012, 07:44 pm
A very "KOOL" cent link at $400+
I will be machining up some end bars and CNCing my own center link.
Just for looks mostly.
Old 21 Sep 2012, 08:22 pm
Originally Posted by rcktpwrd View Post
Thanks
Going to look at my watts link bell crank tomorrow.
Old 22 Sep 2012, 03:27 pm
Dont forget to check the lateral links for wear also, I just replaced my watts link last week, and found the my lateral link tie rod ends were shot as well.
rear suspension ?? puckme1 Wheels, Tires, Suspension 3 27 Feb 2011 11:01 pm
rear suspension problem partyd General PT Cruiser Discussions 6 14 Nov 2010 03:38 pm
stiffer suspension in the rear end? edb Wheels, Tires, Suspension 1 30 Jul 2010 11:14 pm
KYB Shocks, rear suspension jksoft Wheels, Tires, Suspension 3 24 Jun 2010 08:59 am
rear end suspension problems partyd Tech & Performance Forum 7 28 Jul 2009 09:25 am
