eror codes 0344 0016 0522
  • 1 Post By charlesb
Old 22 Sep 2012, 10:05 am
Default eror codes 0344 0016 0522
Hi all have just joined and hope you can help
I am getting the following error codes 0344 / 0016 / 0522 on my 2004 PT standard base wagon not a turbo
Symptoms engine warning light
Oil light comes on sometimes when i start the car if i turn the car off and restart then it goes away
car runs fine for about 6 miles then suddenly loses power I can then nurse it along at 60mph cannot use accelerator hard or it hesitates cannot pull away fast or it hesitates badly will not go over 60 mph
If i leave the car standing for about 2 hours i can then drive it normally with normal performance for about 9 miles then it starts again
please help don't want to change unnecessary parts
Old 24 Sep 2012, 08:23 am
Default Re: eror codes 0344 0016 0522
Welcome to the forum! (From one newbie to another )
I pulled out my Haynes manual, and here's what I found:
P0016 is "Crankshaft/Camshaft timing misalignment" and P0344 is "Camshaft position sensor intermittent" This leads me to suspect the timing belt. I don't know how many miles your PT has, but I would guess it's over 80,000 (at an average of 10,000 miles per year.) The recommendation for changing the timing belt is 6 years/90k, so it's overdue. Your performance problems are probably related to the belt. It could be a faulty sensor(s), but I would have the belt replaced anyway, since your mechanic will likely have to get pretty deep into the engine to diagnose them.
P0522 is "Oil Pressure sending unit input below acceptable voltage." I'm thinking the oil pressure sending unit went bad on you. My '04 Durango does the same thing with the oil light, and I suspect that there, too. I haven't gotten around to replacing it (it's a complicated repair: I'd have to drop the entire front axle assembly!), but that's what I would have checked. Since the timing belt has to be removed to replace the oil pump anyway, you might be able to get everything done in one shot. It's also possible this is related to the timing belt, but only your mechanic can tell for sure.
Even though this isn't good news, I hope this helps you.
graydon1973 likes this.
Charles
2006 Base
Magnesium Pearlcoat
102k miles
Turning into Theseus' ship
Old 24 Sep 2012, 08:40 am
Ray_Dockrey's Avatar
I did some searching and the P0344 points to the camshaft sensor. P0016 can point to either cam shaft or the crankshaft sensor or a timing issue. I would replace the camshaft sensor with a genuine replacement from a dealer and I would also replace the magnet. The P0522 points to the oil pressure switch. They are a known point of failure and again I would replace it with a genuine one from a dealer. Replacement ones form parts stores have been known to be hit or miss.
Old 24 Sep 2012, 05:44 pm
thank you it makes sense the car is over 100k so time to have the belt looked at thank you for the reply and good advice
Old 24 Sep 2012, 07:13 pm
Originally Posted by charlesb View Post
P0522 is "Oil Pressure sending unit input below acceptable voltage." I'm thinking the oil pressure sending unit went bad on you. My '04 Durango does the same thing with the oil light, and I suspect that there, too. I haven't gotten around to replacing it (it's a complicated repair: I'd have to drop the entire front axle assembly!), but that's what I would have checked. .
HOLD ON with dropping the front axle. Most of the guys who replaced the Oil Pressure Sending Unit went from the top of the engine. the battery and few parts of the air filter system comes out pretty easy and they reached down over the top of the engine to replace the sending unit, NOT a complicated repair.
Old 24 Sep 2012, 07:18 pm
Wooops! read that wrong, it's the Durango that needs the front axle dropped to do the sending unit. Sorry. Ours (PT) as I said, isn't that bad.
Old 24 Sep 2012, 08:35 pm
great thanks for the picture that will help
'04 codes read 0522,0335. Stalling at stopsigns and lights? Mawbadical General PT Cruiser Discussions 11 11 Nov 2012 03:54 pm
Camshaft Position Sensor - 0344 djsulli Tech & Performance Forum 1 11 Oct 2011 06:41 am
Error Codes 0522 and 0442 logicalfrank Tech & Performance Forum 3 01 Apr 2010 11:57 am
0340 cleared now 0344? tempest0mouthy Tech & Performance Forum 20 10 Nov 2009 07:04 pm
Help! Hard starting and hesitation - Codes 0171 & 0522 THS_Cruiser03 Tech & Performance Forum 10 08 Aug 2008 02:36 pm
