Battery driving me crazy. Where to start?
Old 24 Sep 2012, 03:49 am
Default Battery driving me crazy. Where to start?
Hi:
I have an EU 2.2 Diesel Limited PT from 2005. Itīs in mint condition with 85.000 KM but the battery is driving me crazy. I've seen some older threads and as they seem to pinpoint precise problems I'd like to have some guidance on where to start and which path to follow. The symptoms are:
About a year ago the battery went dead. I thought it was simply an old battery problem. So I bought a new one (here in Spain is 400 US dollars :-( )
Used it fine with no problems and then left the car without using it for about 3 weeks. When I wanted to start it afterwards, it was dead again. I supposed the kid left a door open and the lights, etc... Charged the battery again (it was 2 or 3 month old, the Mopar OEM one) and then started normally but runs out after 3 days sitting still.
My car has lots of "custom" stuff made by the old owner: an alarm system, and a Blaukpunt CD changer and navigator and a Parrot Bluetooth Handsfree.
I suspect the problem is with something like that (aftermarket stuff) but I'm not sure. Then today I've repeated the test but the car was almost 8 month sitting there with the battery removed. Started after charging it externally and gave it a 30 minutes trip when I started to smell battery gases (my PT has it under the passenger's seat. Then I heard boiling noise and the battery got REALLY HOT. Parked it an itīs there sitting waiting for me to figure this out :-)
Any ideas on where to start? Can the battery being "damaged" by the car so itīs boiling? Or is it boiling because something's really wrong with the car?
Can you point me to any troubleshooting steps?
Thanks a lot!
Old 24 Sep 2012, 09:46 am
Default Re: Battery driving me crazy. Where to start?
Wow yeah that's bad! I'm no expert but if it was starting to boil that would have to be because it was overcharging. Did you ever check the battery with a DVOM in the past?
At idle it should be between 13 to 14 volts I belive? Maybe at some point in the past the battery was not being charged, hence going dead and now it's being overchaged,hence a boiling battery.
Alternator/voltage regulator is the issue at this point. That's what you need to have checked out and you need to dump that battery, I don't think it's safe to use it anymore.
Good luck!
2001 PT Cruiser won't start PLUS crazy power locks hierogrammate General PT Cruiser Discussions 7 03 Nov 2012 04:22 am
Battery drains and won't start, plus no power to anything apalomo01 Tech & Performance Forum 8 08 May 2012 05:34 pm
2006 wont start, battery is good Samson Tech & Performance Forum 13 26 Apr 2011 03:00 pm
Tweeter Hissing - Driving Me CRAZY JuggalotusHeat Sound and Security Forum 20 31 Mar 2011 02:45 pm
This rattle is driving me crazy! HELP! ElectricBlueGT Turbo Wheels/Suspension/Handling 6 19 Dec 2003 10:49 pm
