fuel cut off
Old 25 Sep 2012, 08:08 pm
Default fuel cut off
I have a 2006 touring, non turbo. Last week, it would start but not continue running. We've replaced the fuel pump, and the crank position sensor. Still have the problem. Any suggestions would be SO welcomed. Thanks
M.
Old 25 Sep 2012, 08:11 pm
Default Re: fuel cut off
forgot to add, no engine light, no codes came up...
Old 25 Sep 2012, 08:14 pm
Ray_Dockrey's Avatar
How long does it run? If it just a few seconds and then shuts off it is an issue with the key. The keys have chips in them and if the car doesn't recognize the key it won't run.
Old 25 Sep 2012, 08:26 pm
runs for a few seconds or more...thanks for the help. will check it out..
Old 25 Sep 2012, 08:34 pm
no, used different key. same results. it starts, runs, then runs out of fuel. When you turn on the key, you can hear the pump start, then you hear a "click" at the relay and the pump stops. then turn on the car, it runs then runs out of gas.
Old 25 Sep 2012, 08:43 pm
That's exactly what happens when the key isn't recognized.
Old 25 Sep 2012, 08:45 pm
but Both keys not being recognized? Does that happen a lot?
Old 25 Sep 2012, 09:15 pm
Keys are not bad in this case. It's probably in the ignition switch area. No not often but has happened. Someone should chime in and give a more precise description of the steps to correct.
Old 25 Sep 2012, 11:20 pm
I got no input on the key thing, so I'll go with what I know. Did you check the fuel pressure at the rail?
I think a bad Fuel pressure regulator will produce the same symptoms?
Old 25 Sep 2012, 11:31 pm
Kawizx9r's Avatar
Are the keys you're using the unchipped-type?
I know in most cases, one key is normally chipped whereas the spare isn't. My PT (as well as my friends) wouldn't stay on when the spare was used.
Kawi is a friggin genius!
Clogged fuel filter, low fuel pressure or what? Gilgrin Tech & Performance Forum 8 01 Jun 2016 04:57 am
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
Reg fuel clayp Tech & Performance Forum 7 08 Aug 2011 07:06 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
Fuel spots under fuel door patbluecruiser The Detail Shop 2 15 Apr 2005 07:01 pm
