Engine On Power Source -- Fan Bypass
Old 26 Sep 2012, 07:31 pm
Default Engine On Power Source -- Fan Bypass
Where is the best Engine On Power Source located I'm doing a cooling fan bypass?
Before you asked I've verified my fan works by using the battery. I've probed the relays with a multi-meter and I know high speed is giving power when is suppose to. The Ground appears to be bad on that cable and the connector on the car side is burnt and melted. I cut off the car side connector and hooked up another a 12V and ground and the connectors isn't bad I can get power thru it, but I'm not going to use it since its melted. I've probed around the Power Block and all i'm finding is always Hot Power sources.
Power Source in the Doors??? Koch Interior Accessories Forum 23 29 May 2014 01:49 am
Engine Lacks Power turbinbill Tech & Performance Forum 4 20 Dec 2009 03:00 pm
Subwoofer power source? japbirds Sound and Security Forum 3 18 Sep 2009 08:53 am
Loss of Engine Power. b0b88 Tech & Performance Forum 1 03 Aug 2008 05:20 pm
Best source 12V constant power DJRyan Interior Accessories Forum 3 21 Dec 2007 07:13 pm
