Sudden problem HELP!!
Old 27 Sep 2012, 08:56 pm
Default Sudden problem HELP!!
2004 PT Cruiser FI 154,000 miles
I went out last night and when I accelerated onto the freeway the car just stopped on the on ramp.
The car wouldn't crank over
I got it towed home and after checking on the net found fuse 13 had blown
I also swapped the horn relay with the ASD relay per the net
I replaced the fuse and the car started up and ran ok until I revved it up fast as if I was accelerating onto a freeway Then it surges like it is running out of gas it surges fast once every second and drops rpms when I let off the accelerator it settles back down to idle.
I have no error codes showed none after doing the key check
I can run it up to 3500rpm in park and it runs fine with no stumbling or surging
I haven't tried to drive it yet until I got the good advice from this site.
If it is the fuel pump wouldn't it stumble or surge at 3500 rpm?
Could it be the fuel pump relay?
Any help would be appreciated
Thanks
Old 27 Sep 2012, 09:11 pm
Default Re: Sudden problem HELP!!
The engine has a limiter when in park or neutral. Revving it up to about 3500 and the computer shuts off the injectors so you don't harm the engine. Is that what your talking about?
Old 27 Sep 2012, 11:23 pm
That's what it is doing ,thanks!! Even when I floor it it doesn't cut out until above 3200 rpm
I'll have to test drive it and see what happens I still don't know what blew the fuse maybe a bad ASD relay. I did swap relays before replacing the fuse. I knew I would get an answer here!!!
Old 28 Sep 2012, 05:07 pm
Well I took it out for a little drive and all seems well, do I have to worry about it blowing the fuse again?
Old 28 Sep 2012, 05:26 pm
Simple at this: if you didn't find out WHY the fuse blew in the first place, there's always a chance it might blow again. Keep a couple spare fuses handy and keep your fingers crossed.
Old 28 Sep 2012, 06:47 pm
That's what I'm thinking, could it have been the ASD relay itself?
Old 28 Sep 2012, 07:14 pm
The ASD causing other things to go bad, sure but never heard of it blowing other fuses. Doesn't mean it can't happen.
Old 29 Sep 2012, 04:13 am
Probably not the relay itself but rather what it controls...typically: generator field, ignition coil, injectors.
Old 29 Sep 2012, 02:55 pm
I drove around town today with no problems so hopefully it was a glitch I ordered a new ASD relay since the old one was 8 years old and so is the horn relay I put in the blown one's place.It does make me mad that a $17 relay can strand you and cost $75 to get home and if not for this board and the net It could have cost hundreds from a dealer. This is why I like 40 year old cars!
Thanks for the advice and I hope I don't need to ask again.
Old 29 Sep 2012, 03:13 pm
It does make me mad that a $17 relay can strand you and cost $75 to get home .
A couple burnt wires will do the same thing.
sudden drop in mpg geocacher General PT Cruiser Discussions 9 13 Sep 2012 01:08 pm
Sudden no start...? 06ptbruiser Tech & Performance Forum 4 26 Jan 2011 09:28 pm
Sudden drop in gas mileage ptjoe Tech & Performance Forum 11 08 Nov 2009 03:46 pm
Sudden whining out of my turbo pt artbumm General PT Cruiser Discussions 12 28 Apr 2007 04:03 am
Sudden Engine Misfire VTX1800Dave General Turbo Discussions 22 07 Feb 2004 10:09 pm
