Torque mounts...don't last worth a damn!!!
  • 1 Post By mdskinner731
Old 29 Sep 2012, 01:23 pm
wheelgarage's Avatar
Default Torque mounts...don't last worth a damn!!!
Okay, I am going on my third set now going to 130k miles...
This time around I am changing the transmission mount and both torque mounts. Hopefully, this combination will last AT LEAST 60k....
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Old 29 Sep 2012, 02:00 pm
xwing777's Avatar
Default Re: Torque mounts...dont last worth sh*t!!!
Get a tube of windshield urethane and fill the open areas in the strut. Let set for a few days to cure and you will never need to replace them again.
Old 29 Sep 2012, 02:02 pm
Send a message via MSN to Pipeous
do you guys even refill the used/old mounts with this urethane? I was going to be doing all my mounts next repair escapade but if I can get away with just filling all my old ones then that'd be much cheaper and could do it right away
2003 Dream Cruiser
The Mean Tangerine: Pteazer Smoothie front fascia, Roadster grill, and Retro real roll pan, dual exhaust, 17" Momo wheels, Eibach lowering kit, 2005 intake, bov, 5 speed manual tranny, painted door pillars, altezza tail lights, hurst short shift kit, hard pipes, halo fog lights and stage 1 computer and injectors
Old 29 Sep 2012, 02:04 pm
There is a third motor mount. Also try high performance neon mounts. They have more rubber in them. Or urethane your old ones.
Old 29 Sep 2012, 08:51 pm
Default Re: Torque mounts...don't last worth a damn!!!
Well, I ordered new ones from RockAuto again. I will be urethane'g them when I get them....
Old 29 Sep 2012, 09:01 pm
mdfrodolives's Avatar
Dang!
I just bought mine at Autozone and they are doing fine.
Duralast. Lifetime guarantee.
Tim
Old 30 Sep 2012, 10:44 am
Originally Posted by mdfrodolives View Post
Dang!
Tim
i tore the duralast mount in a week. then i filled it because i didnt want to play the warrantee game every week. then the bolt broke. i replaced it with a rear lower control arm bolt from a mustang and added a large fender washer. it's been great ever since.
i later learned there is an adjustment procedure i skipped. i tend to accelerate hard and downshift constantly. also i hardly ever use the clutch when i'm changing gears which i'm sure doesn't help much.
yes. the one i filled was torn completely in half. i removed as much of the stock rubber as i could before i filled it. the only rubber i left was to help me align the pieces properly.
Old 30 Sep 2012, 01:26 pm
Don't need to remove any of the rubber if you don't want to. Just needs to be clean so the urathane bonds well.
Old 01 Oct 2012, 07:22 am
davea300's Avatar
The urathane method is superb! I bought some a few months back and did both mounts, all vibrations away! One of the best tips I've found on here and yes my mounts were old!
2005 2.4 PT CRUISER (UK SPEC)
Short ram intake, chrome grill, chrome belt line, drilled/slotted discs, few flames, engine dress up, chrome bits and pieces.
67,000 miles
Old 01 Oct 2012, 11:39 am
mdskinner731's Avatar
Energy Suspension 5.1109 Motor Mount Inserts Dodge SRT4 03-05
i tried these when i did my build on the cruiser. i have had no issues at all. work great and comes in different collors too (if you want a show car)
XtrmDC2 likes this.
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
FS: Upper & Lower Motor Mounts (Torque Struts) 808 Classifieds: For Sale/Trade 18 10 Jul 2012 10:30 pm
Engine rock and squeak, not torque mounts?? greasebaboon Tech & Performance Forum 3 07 Mar 2012 08:07 pm
performance motor and tramision mounts and "torque struts" srebik Tech & Performance Forum 3 31 Jul 2010 01:51 am
This why you DONT Cut! ! ! ! 02PT Wheels, Tires, Suspension 12 19 Sep 2009 10:37 am
to torque or not to torque -oil and plugs thinguy Turbo Performance 12 29 Jul 2003 05:10 pm
