Engine Mounts!?
Like Tree3Likes
Old 01 Oct 2012, 02:31 pm
Default Engine Mounts!?
Okay, please don't scold me. I've spent the last couple hours scouring the web in search of answer. And I seem to be getting conflicting information.
Firstly, I've got a 2001 Touring Edition. 2.4. Automatic. All Stock. 140000 Miles.
There's a lot of clunking going on in the front end. I know for sure that one culprit is the engine mounts. They've never been replaced. And I've got 140K. So I'm assuming they're shot.
Here’s the questions I have, and cannot find a definite answer to:
How many engine/trans mounts are there? 4 or 3? I have the service manual, and it states 4. Other people claim 3. I see kits on eBay that contain 2, 3, or 4 mounts. Which should I get?
Secondly, which of these mounts will likely need replacing? I know the upper and lower strut mounts are a MUST, but what about the others?
I’m going to be replacing these myself within the next few weeks, and I only want to have to do it once. Thanks an advance for the help; really appreciate it.
Anything but going to a dealer…
Old 01 Oct 2012, 02:41 pm
Default Re: Engine Mounts!?
there are the two torque struts,
one centered mount in between them that bolts to the timing cover(and hardly ever goes bad/is difficult to get to)
and one mount below the battery tray that attaches to the transmission
most likely you just need the 2 torque struts. if you do spirited driving, you should fill them before installing them
Busted_PT likes this.
Old 01 Oct 2012, 02:46 pm
Badglas's Avatar
Your PT has 4 mounts for the drivetrain. The upper strut, lower strut, main(center) mount, and the transmission mount.
Upper and lower struts will be broken at that mileage, the most likely culprits. The main mount can only be replaced by removing the motor, or when replacing the water pump. It is probably worn, but I doubt it is broken. The transmission mount is located under the battery tray and power center. It is easily replaced from above. I'm sure it is worn, but I doubt it is broken either.
Make sure to follow the FSM when replacing any of the mounts. The upper strut has to be installed with a precise measurement of position.
Good luck!
Ron
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 01 Oct 2012, 08:30 pm
Okay, thank you all for the info.
Now, I'm probably NOT going to be changing out that mount that requires engine or waterpump removal. That sounds like a bear.
Maybe I'll just do the upper and lower strut mounts, and the tranny mount.
Lastly, is this the tranny mount? And if so, why does it say it only fits the 2003+ model years...?
Transmission Mount 2001 - 2002 Chrysler PT Cruiser 2.4L | eBay
Old 04 Oct 2012, 06:43 pm
Bump. Any thoughts?
Old 04 Oct 2012, 07:41 pm
to answer your question:
no, that is the timing cover engine mount. this is the transmission mount:
ANCHOR 3026 Transmission Mount | eBay
you should probably just skip this one too.
just get the upper and lower torque struts. they are probably all you need.
Badglas likes this.
Old 06 Oct 2012, 07:56 am
How is this done to the bog bone/torque strut mounts?
Old 06 Oct 2012, 09:17 am
here's mine i filled:
Butt Head's Photos | Facebook
it's called 3m windo weld. you can find it online or at some parts stores. i used a generic version called titan p2g because i found it cheap on ebay.
keep in mind you have to let it dry completely before installing it. this takes (at least) a full 2 days. you can speed it up by cooking it in the oven at a low temperature, but i didn't.
Old 06 Oct 2012, 09:26 am
Old 06 Oct 2012, 09:30 pm
That's awesome to know....now I don't have to buy new ones.
2001 Purple PT Cruiser (Mine)
2007 Sliver PT Cruiser (Wife's)
Engine Mounts bheffner PT Cruiser Convertible Forum 2 06 Sep 2012 10:37 am
engine mounts lt4supr Turbo Performance 25 05 Oct 2011 01:19 pm
engine mounts lt4supr General PT Cruiser Discussions 11 04 Jun 2008 07:56 am
Engine mounts KingKole02 Tech & Performance Forum 3 13 Jan 2005 04:04 pm
