Replaced heater core still overheating
Like Tree4Likes
Old 02 Oct 2012, 06:37 am
Default Replaced heater core still overheating
I have 2004 pt and replaced the water pump, thermostat, and the heater core twice. When I bypass the heater core no problem but with it hooked up it overheats, it leaks fluid on the inside of the car and on the outside. There is a tube that comes out of the firewall that drips water/antifreeze once the car gets hot. Im at a loss as to what to look at replacing next. I read on one thread the radiator my question is would it not still overheater even with the heater core bypassed. Im open to suggestions. This is getting very expensive as this may be the third time the heater core has to be replace . Since it is overheating / leaking Im assuming it will need to be replaced also.
Help please.
Old 02 Oct 2012, 07:12 am
Default Re: Replaced heater core still overheating
Once you replaced the core, I don't know why you didn't start looking at other options. One core replacement is enough. Look at the lines/tubes for a blockage and double check the connections to the core.
Simple, if you bypassed the core and it doesn't overheat, then the problem is the coolant getting into/out of that area not letting the coolant cool off the engine. That's the way I see it anyway.
Old 02 Oct 2012, 09:15 am
Faint coolant smell inside
i'd assume you need to purge the air out properly. when you bleed the coolant system the heat knob is supposed to be set to hot and the fan set to high. otherwise the heater core is cutoff from the system and air will remain trapped in there.
Old 02 Oct 2012, 08:22 pm
I replaced the heater core a second time due to it leaking inside the car. It was fogging up the windows, steam coming out of vents and dripping on carpet. Once replaced it ran ok for about a month, spring came so I disconnected the hoses from the heater core tied them together and had no heating issues during the summer, now it is fall getting cooler and I reconnected the hoses to the HC to have heat, now it is overheating and whatever the tube in the firewall is continnually drips. If the problem is in the line would it not over heat all the time? Im really dumb to this stuff and have taken it to a mechanic who replaced the thermostat waterpump, and heatercore. He says its just cheapmade platic cores going bad, but I think there has to be other issues.
Thanks for any input
Old 02 Oct 2012, 09:10 pm
First off what possessed you to unhook the heater core to begin with. If it wasn't leaking. Assuming you actually got a new one and not a block seal job. You most likely broke it removing and installing the hoses. In the process allowing air and the leak to cause an overheating issue. If you have been doing this on a regular bases then this would explain you you have had an extraordinarily high number of heater cores leak.
Badglas likes this.
Old 03 Oct 2012, 06:33 am
The reason I unhooked the hoses is because it was starting to leak/have that radiator smell inside the car and the windows fogging up/becoming greasy from the antifeeze. It was spring so I unhooked the hoses. The first time the heater core was replaced It worked maybe 3 weeks, then I took it back to the mechanic and he replaced it. This ran throughout winter but then as spring started to come around it started leaking. So I unhooked it ran through the summer now I have rehooked. What is causing the heater core to continue to leak? Is it because of the plastic and metal design as the mechnic told me? Is it the radiator like I read in another post? Or something else? I dont know where to start looking or even if I should continue to trust this guy. Ive read on here this seems to be a common problem. Like Ive said eariler replace waterpump, thermostat, and heater core. Why does it run hot when heater core is connected but fine when it is not? If the radiator was bad would it not run hot all the time? Im not even a back yard mechnic, but I do ask for your experience so I have an idea what to ask the mechnic to look for. All I want is some heat this winter without the car running hot and leaking the fluid.
Old 03 Oct 2012, 07:29 am
Ray_Dockrey's Avatar
First, I would find another mechanic. Heater cores are not a common issue. Not that I have seen. Yes overheating is. My guess is that when you hook the heater core back up it is overheating due to loosing coolant and you probably have air in the system. These cars are hard to bleed all the air out.
I would have a different mechanic replace the heater core. Then go from there.
Busted_PT likes this.
Old 03 Oct 2012, 08:02 am
Like Ray said get you another guy. Seems they most likely didn't give you a new one to start with. Once is as common as it gets. And the heating is as Ray said.
Sorry about the grumpy post But here is the skinny on the problem.
When you have a leak it forces water out when hot then when it cools of it sucks air in instead of pulling from the resavior. The leak also lowers the boiling temp of the water by lowering the pressure in the system. This is why you are also over heating. It's all from the leak.
Old 03 Oct 2012, 01:08 pm
UptownSport's Avatar
Controls have no authority over heater core flow whatsoever-
The heater core is of the 'constant flow' design, unlike other vehicles which limit or shut off flow. (Core doubles as a 'bypass' so thermostat has coolant flowing past)
Ray_Dockrey likes this.
Old 04 Oct 2012, 10:41 pm
learn somethin' new every day (:
Heater core TMas777 Tech & Performance Forum 8 13 Oct 2011 04:31 pm
Heater core in o3 pt bryanschacht General PT Cruiser Discussions 4 02 Feb 2011 06:04 pm
More heater core questions ddash General PT Cruiser Discussions 0 20 Sep 2010 02:23 pm
Heater core and rad replacement ddash General PT Cruiser Discussions 4 14 Sep 2010 06:35 pm
