Cam Angle Sensor, Surging/Governing Signal Occasionally
Old 02 Oct 2012, 11:13 am
GTCRUISER2006's Avatar
Default Cam Angle Sensor, Surging/Governing Signal Occasionally
Hello All,
I'm getting the Cam Angle Sensor A check engine code. The car goes into "limp" mode and the light comes on. Then you stop the car start it again and the car is out of "limp" mode. The check engine light resets and disappears. But, then it happens again etc. So, my question to you all is.. Can the problem be the cam angle sensor if it does not always go on and does not stay on? Can a sensor work and not work, intermittently? Could it be something else? Should I just start by replacing the sensor? Thank you for your time in advance. Obviously, I'm not super mechanically inclined.
GTCRUISER2006
2006 GT Cruiser HO w/ 5spd. Tastes Like Vanilla!
Old 02 Oct 2012, 11:17 am
Default Re: Cam Angle Sensor, Surging/Governing Signal Occasionally
Mine did the same thing for a few weeks until the car wouldn't start anymore...That's when I changed it
Cam Angle Sensor, Surging/Governing GTCRUISER2006 Tech & Performance Forum 1 27 Jul 2012 10:47 am
engine light on occasionally po243 thejester Tech & Performance Forum 6 01 Jan 2012 08:28 am
Code 1391 Sometimes I can't see the crank or cam sensor signal CandaceMoore Tech & Performance Forum 8 29 Jul 2010 08:06 pm
Lever to adjust seat angle broken Edwin Astacio Interior Accessories Forum 12 18 Nov 2009 12:38 am
PT won't start OCCASIONALLY hammiesink General PT Cruiser Discussions 6 29 Oct 2009 07:47 pm
