2005 camsensor wire harness replacement?
Like Tree3Likes
  • 1 Post By Busted_PT
  • 1 Post By Badglas
  • 1 Post By mojeb21
Old 03 Oct 2012, 06:37 pm
Default 2005 camsensor wire harness replacement?
Hello.
getting a P0340 code and i looked at the camshaft wire harness and it appears to have been burned by the engine and now i can see some exposed wire.
what i see is the three wires that run from the connector at the cam sensor run into a large harness.
my question is: can i cut the wire behind the bad wires and replace(splice) with a new harness and connector or do i have to open up the big harness and find the "start point" of the wires
Old 03 Oct 2012, 07:05 pm
Default Re: 2005 camsensor wire harness replacement?
You don't want to do that if all the damage is out away from the main harness. But you should solder and whether proof your splicing. Just section out the damage area. Secure to a safe place so you won't have this again.
Badglas likes this.
Old 03 Oct 2012, 07:44 pm
Badglas's Avatar
Agreed! Just replace the damaged area. Solder and heatshrink are a must. They do make a crimp style connector that has solder and heat shrink built in. Crimp the wire into each end, and then heat with a small torch.
Ron
Busted_PT likes this.
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 03 Oct 2012, 08:50 pm
thanks guys!
i cut back just behind the damage area and got some crimps with attached heat shrink on them
i was nervous about one of them because it didnt seem solid but it works amazing! lets hope it stays that way! . im going to buy some shielding to put around the wires and find a spot to attach them to keep them away from the engine block again.
Old 03 Oct 2012, 08:58 pm
Originally Posted by mojeb21 View Post
thanks guys!
You da man!
New wire harness kit has 2 constant and 2 grounds? fishkiller12672 Sound and Security Forum 4 28 Oct 2011 10:36 am
injector wire harness, fuel rail curtis1993 Classifieds: Want To Buy 0 22 Apr 2011 05:57 pm
wire harness for new head unit ckanders General PT Cruiser Discussions 3 28 Mar 2007 03:31 pm
correct speaker wire harness for front speakers Curruzr General PT Cruiser Discussions 4 12 Aug 2004 04:01 pm
