Fused 13 keeps popping?
Old 04 Oct 2012, 03:05 pm
Default Fused 13 keeps popping?
04 Cruiser Number 13 fuse pops fp/asd. Car is running very rough Stays on for about 5 seconds And then pops fuse 13. I know that fuse is on many things What I have done to diagnose so far is O2 sensors disconnect 1 by 1, change coil pack, replace wires and spark plug, disconnect 1 by 1 fuel injectors, look at wiring seems to be okay, replace resistor by the air filter, not able to correctly diagnosis fuel pressure cuz of no nipple on fuel rail did disconnect fuel line that's on the firewall and inserted my fuel pressure tester when I prime the fuel pump it reads at 55 pounds so I'm guessing fuel pump maybe okay. I researched all over and see many of the same problem but no 1 post the end result of what was the problem and how to fix it. Thanks in advance For anyone that can help me. By the way I am located in Chicago if any chrysler technician In the area can help.
Old 04 Oct 2012, 03:27 pm
Default Re: Fused 13 keeps popping?
By the way it's non turbo
Old 07 Oct 2012, 08:07 am
Anyone??? Please
Old 07 Oct 2012, 09:47 am
OK, here's a little something I found that I answered awhile back. You can skip the rest of the thread once the answer is given, just a little back-and-forth between a new member and myself.
BLOWING FUSE 13
Old 09 Oct 2012, 10:11 pm
Disconnect fuel pump fuse does not blow so I replace fuel pump dam fuse still blows check the wiring from fuel pump down to firewall where the plug is down by the axle (checked with a meter) good. So I'm thinking maybe it's the brain box cpu or the wiring from the fire wall down to computer. What u guys think?
popping and hissing moorepc Tech & Performance Forum 4 27 Jan 2012 08:50 pm
Popping out of gear JJ66 Tech & Performance Forum 4 26 Jun 2010 08:19 pm
Popping noise i Decsr PT Cruiser Convertible Forum 1 31 Mar 2009 04:47 am
Fog Light getting fused too often LoboMXGT Exterior Accessories Forum 4 24 Sep 2005 11:48 am
More Popping Sound AGAIN jmack General PT Cruiser Discussions 15 04 Aug 2004 04:18 pm
