MY 2ND GEAR GRIND!?
Old 05 Oct 2012, 12:06 pm
Exclamation MY 2ND GEAR GRIND!?
Hi guys, when i try shift quickly or at high rpms in my pt it will grind, also when i down shift at higher RPM's what could this possibly be before i endup replacing the transmission :
Old 05 Oct 2012, 12:20 pm
Default Re: MY 2ND GEAR GRIND!?
non turbo?
how many miles?
how do you drive it?
check the fluid. is it oil, or ATF?
either way, sounds like you're due for new synchros. i'd guess you either beat the piss out of that thing daily or it wore out quick due to the wrong fluid(or both).
i'm at 247k miles and mine shifts fine at redline with the gas pedal still smashed to the floor
Old 05 Oct 2012, 12:46 pm
its an 03, 146k on it, i dont drive it hard, i get on it every once and a while dont get me wrong but i dont ratch on my cars. i have not checked my synchros though or fluid. how do you know if your synchros are bad??
Old 05 Oct 2012, 12:47 pm
also its turboed
Old 05 Oct 2012, 12:48 pm
UptownSport's Avatar
Could be- Dragging clutch either clutch (clutch disc broke apart from marcels or warped 'flywheel' / pressure plate) or underdash adjustment will cause this too-
I've had lots of these things, synchros worn well beyond specs or not and it really didn't seem to make a diff.
The t-350 trans / shifter isn't equipped with stops, so take care to limit exuberant shifts- you can and people do bend forks.
If you're experiencing this in several gears, or get the 'clunk' when first engaging 1st / R suspect clutch related issues.
3- R synchros can be replaced with moderate-moderate high skill levels, along with ALL shift forks (These DO fail). 1-2 aren't available aftermarket, but one guy claims to be able to get them new.
Old 05 Oct 2012, 12:52 pm
okay i have heard a clunk before when shifting to rev and also have herd this when its colder shifting to 1st...so it could be the clutch possibly?im just confused on what to do, what would be the quickest thing to try?? change the tranny fluid??
car will not gear up :( kerenmantilla25 General PT Cruiser Discussions 9 30 Jun 2012 06:55 pm
no 3 or 4 gear JaviPTGT Tech & Performance Forum 11 03 Apr 2011 02:02 pm
disc brake grind and buildup yourlefthand Tech & Performance Forum 3 24 Nov 2010 01:17 am
p0733 Gear 3 Incorrect ratio p0733 Gear 3 Incorr RobGT General Turbo Discussions 12 04 Nov 2004 02:02 pm
Looking for 03/04 GT Gear box Kboom General Turbo Discussions 4 29 Oct 2004 05:00 pm
