help with a couple codes
Old 06 Oct 2012, 12:56 pm
1972cudaguy's Avatar
Default help with a couple codes
Went to take my PT for an Echeck this morning , when I started it up had the light on AARRGG!!
can someone tell me what this code means ?
P0141 HO2S Heater Performance Bank 1 Sensor 2
Old 06 Oct 2012, 02:53 pm
Default Re: help with a couple codes
It's the Oxygen sensor at the CAT.
Old 07 Oct 2012, 05:52 am
Just replaced it Crewzin . The light went out for a couple days then back on again . Gonna crawl under it later & check connector & wires the end of the sensor seems awfully close to the trans tunnel
Old 08 Oct 2012, 09:37 pm
My DTC guide shows it slightly different:
Code:
P0141 O2 Sensor Heater Circuit (Bank 1 Sensor 2)
This does not indicate that the O2 sensor is the problem, even though it can be.
Now, based on my research and my collection of PT Issues, I've combined all that I can find on all DTC's along with suggestions for corrective actions. Here's what I've collected on P0141:
Originally Posted by Chromenut's Library
P0141 1T CCM 2003 PT Cruiser
O2 (B1 S2) Heater Circuit Conditions: ECT Sensor less than 147F, BTS signal within 27F of ECT Sensor (cold engine); engine running at idle speed for over 12 seconds, system voltage over 10.5v and the PCM detected the O2 signal was more than 3.0v for 30-90 seconds. Possible Causes: ASD relay output (power) circuit to the heater is open O2 heater ground circuit open or O2 signal circuit is open O2 heater element has high resistance O2 heater element has failed (open or shorted) PCM has failed
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
codes (again) and new... a couple weeks back got a p0300 batta Tech & Performance Forum 7 01 May 2010 10:33 am
Couple of questions JoeHundredAire Tech & Performance Forum 4 13 Apr 2009 07:06 pm
couple questions phre0n Tech & Performance Forum 4 19 Dec 2007 01:02 pm
