this car is hard to steer with the belt off
Like Tree7Likes
  • 1 Post By NitroPT
  • 2 Post By NitroPT
  • 1 Post By CREWZIN
  • 2 Post By rob342
  • 1 Post By UptownSport
Old 06 Oct 2012, 04:55 pm
Default this car is hard to steer with the belt off
i'm shocked how hard this car is to steer without power steering!
on mustangs we'd clip the power steering lines, crimp the tubes, and throw the compressors in the garbage. i expected it to be like that. it's NOT. LOL!
i took the belt off and went for a test drive because my tensioner is making the most god awful metal on metal grinding noise! the noise was so bad i was afraid something was going to seize, break the belt, poiisbly tangle or cause the alternator belt to jump off, and strand me.
so whatever.. found the problem. i figured i'd take the pulley off and replace it. well.. apparently the bolt that goes through the pulley is ridiculously long. after i unscrewed it an inch it(the bolt) hits the frame. grumble. so.. i pry the engine over as much as i can with a block of wood to gain clearance, get it out another 1/4" or so, but still can't get it out. whatever.. i put the bolt back in.
i use my super google skills to look for the size of the other bolt, the one i can't see. the one that holds the tensioner on.. well, i stumbled across a tip about supporting the engine with a jack and removing the center engine mount bolt in order to lower the engine and get more clearance. -i really hope i do not have to do that. also i never found the bolt size
heh. i do like the way i can feel the road better.
and
i was pleased to find the noise was coming from the cheapest possible part
:P
Old 06 Oct 2012, 05:21 pm
Default Re: this car is hard to steer with the belt off
Hey rob342 I know that you know this but others may not so it is for those others.
If you run a power steering system like the one on the PT for very long without the aid of the pump you not only lose the hydraulic pressure multiplier but you also lose the circulation of power steering fluid throughout the steering mechanism. This loss of lubrication will cause the steering system to fail over time. Also because of the difficulty in turning and reacting to possible evasive steering maneuvers your mechanical steering reaction time is reduced.
Busted_PT likes this.
Old 06 Oct 2012, 06:54 pm
rob342 @ week 2 with the upper body fitness program #5 no power steering belt 20 minute work out.
UptownSport and rob342 like this.
Old 06 Oct 2012, 07:10 pm
i see the pulley for $26 at autozone. hopefully i can find it in stock somewhere tomorrow (:
Old 07 Oct 2012, 05:10 am
Teska's Avatar
My power steering failed on me once and I had to drive about two weeks without. I couldn 't let my wife drive it cause it's simply impossible to turn the wheel without some amount of (male) force.
In my case it suddenly started wordking again after a mechanic looked at it and did nothing but look. It's still working nowadays, it's only hard steering on idle.
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Old 07 Oct 2012, 09:09 am
compdr59's Avatar
Flush the power steering fluid while your working on the car. Use ATF +4. All major auto parts stores should have your idler pulley. The bolt barely cleared for removal, so I didn't have to remove the entire tensioner assembly. You can always order one RockAuto too.
Original Owner 135k
Old 07 Oct 2012, 10:07 am
My Power Steer Pump went out at about 30K, just after the warranty ran out. I guess it was just before a right hand turn and when I tried making that turn it felt like i was driving an 18-wheeler Mack truck. Almost didn't make it around and headed towards the concrete center divider. Fortunately my adrenalin kicked in and was able the pull the steering wheel around to miss the divider.
UptownSport likes this.
Old 11 Oct 2012, 03:03 pm
i just fixed the tensioner and put the belt back on. it's weird! it's so easy to turn it reminds me of driving my friends '84 cadillac with the pimp knob on the wheel. it's amazing how easily the tensioner is removed with the car up on a lift.
i did not get any sore or bigger muscles from the week of hard steering. yesterday i did get a cab driver glaring at me in disgust while i wrenched on the wheel to parallel park, you know while accidentally hitting the horn, wipers, and signal.
OurPTGT and UptownSport like this.
Old 11 Oct 2012, 03:13 pm
UptownSport's Avatar
ROFL!!
Shut mine off and figured I'd 'cruze' into a park spot on armstrong steering.
Definitely didn't feel like Popeye for those two seconds
OurPTGT likes this.
Timing belt tensioner is giving me a hard time damilleniumboy Tech & Performance Forum 5 24 Nov 2011 08:57 am
TIMING BELT HARD TO GET ON Cruz2success Tech & Performance Forum 1 13 Sep 2011 10:32 pm
power steer cruizinla Tech & Performance Forum 1 29 Dec 2008 10:24 pm
torque steer GTSteve Tech & Performance Forum 2 24 Sep 2003 01:18 am
torque steer Punch Turbo Performance 9 07 Sep 2003 08:18 pm
