Quick Q about front wheel bearings...
Old 09 Oct 2012, 05:05 pm
Default Quick Q about front wheel bearings...
33mm "first design or 39mm "second design" on an '01 PT? Will either work? Any preferences here?
Old 09 Oct 2012, 06:42 pm
Default Re: Quick Q about front wheel bearings...
33mm for 01. usually they'll ask for the first 8 digits of your vin to make sure. i put the 33mm in my 02 and didnt make it a mile
Old 09 Oct 2012, 10:36 pm
UptownSport's Avatar
You'd need to swap hubs and the little tin retainers to swap
Old 10 Oct 2012, 04:21 pm
Got it... didn't know if the different sizes were a design revision or a totally different hub design. I've got two cars where the manufacturer started specifying a slightly wider front wheel bearing or adding shims to cure a clunk. Sounds like the PT actually has totally different hubs. This is a very early one, so I suspect 33mm is the answer.
I need to admit, I'm a little excited about doing this job. I bought an OTC Hub Grappler over the summer, and this will be only the third opportunity I've had to use it.
What I am not looking forward to is potentially replacing the oil pan. That girdle looks gnarly.
Old 10 Oct 2012, 08:42 pm
The hubs are a little different;
so the retainer needs to stick out more- I suppose one could (only us Neon drivers) use '01 retainer and just leave gap between it and knuckle
Old 12 Oct 2012, 12:11 pm
Thanks! I imagine this car is stock top to bottom, but perhaps I'll wait til I pull the old ones out before ordering new ones, just to be safe.
Old 12 Oct 2012, 08:34 pm
You can tell if you have a trained eye by just pulling the rotor
Old 26 Mar 2020, 10:47 am
I need to admit, I'm a little excited about doing this job. I bought an nitto terra grappler over the summer, and this will be only the third opportunity I've had to use it.
Do you require a solidly built set of dependable and reliable all-terrain tires to carry you through your day’s routine activities, but when the weekend hits, feel the need to strike out on a trail, or haul a camper?
Source for good front wheel bearings hornpipe2 Wheels, Tires, Suspension 12 10 Oct 2012 07:59 pm
Finally got my front wheel bearings replaced! sscanlan General PT Cruiser Discussions 0 14 Jan 2012 07:22 pm
SKF or Timken front wheel bearings? Samson Tech & Performance Forum 7 08 Jan 2012 04:29 pm
Best front hub/wheel bearings to buy? Samson Wheels, Tires, Suspension 9 13 Aug 2010 11:45 am
How many front wheel bearings? scrisp2 Wheels, Tires, Suspension 0 22 Mar 2010 11:24 am
