Shifter is popping out of gear
  • 1 Post By CruiserLady
Old 10 Oct 2012, 03:56 pm
Default Shifter is popping out of gear
Hello all.. this is my first post here. I have a 2003 PT that I have had since day 1. I love the car and really want to get it fixed or fix it myself. Here is my problem... I have a 2003 base model with 120K and a 5 spd standard trans. The problem is that that the trans/stick shift pops out of gear as I am going down the road. I can usually hold the stick in and keep it in gear but sometimes it bucks/pops out of gear to hard and I do not like doing that. It does it constantly some days and other days hardly at all.
If anyone has anything I can check let me know.
Thanks and darn glad I found the forum.
Old 10 Oct 2012, 04:12 pm
Default Re: Shifter is popping out of gear
one gear or all gears?
Old 10 Oct 2012, 04:14 pm
Sorry should have stated that.. it is mostly when at highway speed but have noticed it in lower gears too.
Old 10 Oct 2012, 06:48 pm
Hmmm, I wonder if your shift linkage bushing is gone.
UptownSport likes this.
Old 10 Oct 2012, 08:15 pm
TurboDucky's Avatar
Also check your fluid level in the tranny. I've seen low fluid cause the synchros to heat up and push it out of gear.
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Old 10 Oct 2012, 08:25 pm
UptownSport's Avatar
Yep! Just order 'Booger Bushings' and install. They're like $20 or $25 shipped. Straightforward to install, and you'll think you have a Porsche shifter!
On ebay or order direct from boogerracing.com or similar
(See the how-to, should be in my signature links- Think it was Chromenut who wrote it)
Popping noise under gear nob cee48 Tech & Performance Forum 0 28 Dec 2010 12:29 pm
Popping out of gear JJ66 Tech & Performance Forum 4 26 Jun 2010 08:19 pm
Gear Shifter cruisergeo Interior Accessories Forum 8 07 Jan 2004 03:11 pm
my new gear shifter cmypt Interior Accessories Forum 1 14 Jan 2003 01:31 pm
