P0551 Code Mystery
Old 10 Oct 2012, 09:55 pm
Red face P0551 Code Mystery
I have a 2003 PT Cruiser with 70K on the odometer. I have a P0551 code which is the power steering pump sensor. When I took it to my mechanic, he said he removed the sensor and noticed fluid inside. There were no other signs of a leak and no dripping. He dried off the sensor and the code cleared. About 25 miles later and the code returned. It sometimes goes off, but it usually comes back. Do I need to replace the pump? Is there another fix?
Old 10 Oct 2012, 11:42 pm
Default Re: P0551 Code Mystery
hope this helps.
How-To: Replace Power Steering Pressure Sensor - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11 Oct 2012, 01:31 am
Unhappy Re: P0551 Code Mystery
Thanks for the info. I guess what I'm really looking for is, if the switch has fluid inside it's setting, is the pump faulty or about to fail? Or is it possible a seal just needs replacing?
Old 11 Oct 2012, 02:32 am
if it were me, i'd buy it and see if it fixes the problem. rockauto has em for around 20 bux.
i only say that because a lot of people on the aforementioned srt forums claim it worked for them.
Old 11 Oct 2012, 09:01 pm
Thanks soyomb. That's the best advice I've gotten so far. A $20 seal beats a $400 pump. If it doesn't work I'm only out $20.
Old 11 Oct 2012, 09:15 pm
The pressure sensor is easy to replace but a messey job. There's no way to get the sensor out and the new one in without loosing fluid so be warned.
Tags
2003, limited edition, p0551
the dreaded p0551 code - stumper djfox1 Turbo Performance 17 16 Apr 2016 08:14 pm
Code p0551 LNBNDN Tech & Performance Forum 4 26 Oct 2011 08:51 am
P0551 Error code janz Tech & Performance Forum 5 04 Aug 2010 03:26 pm
Remedy for a P0551 Code silentsam74 Tech & Performance Forum 1 06 Sep 2007 07:34 am
Code P0551 - How Serious? BB General PT Cruiser Discussions 8 17 Aug 2005 11:12 pm
