Thermostat & Flushing??
Old 13 Oct 2012, 08:55 am
Wink Thermostat & Flushing??
getting ready to change my thermostat in my '06 GT, preventive maintenance, never changed one on a PT before...any pointers??-are the gaskets/seals re-useable? I've seen 2 types listed-one looks like a rubber "O" ring, the other looks like a conventional composition gasket.
AND.. as far as cooling system flushing at home, what is the best way on a PT? can I install a Flush n Fill "T" in the heater hose and flush with a garden hose like older vehicles?
And just what type of anti-freeze is in it from the factory? (its RED, thats all I know) --I use Peak FINAL CHARGE RED Extended-Life coolant in my Diesel pickup, CAN I use it in the PT as well?
Thanks A Bunch folks!
Old 13 Oct 2012, 05:49 pm
Wink Re: Thermostat & Flushing??
wow, no one has changed their Tstat yet? our '06 is now 6 years old and almost 50k miles.....I know the coolant is most likely extended lift stuff, but I'd really like to change the TStat...and figured why not flush the system as well while its down.........
Old 13 Oct 2012, 06:09 pm
rcktpwrd's Avatar
Default Re: Thermostat & Flushing??
Do you have the t-stat already? They usually come with a new gasket, if it didn't it's the o-ring style, the paper gasket is for the housing to block.
For coolant you want to use either the Mopar stuff or Zerex G05.
Joel
www.rcktpwrd.com
Old 13 Oct 2012, 08:16 pm
Thanks! I have the TStat coming, and a new cap as well-mine is just starting to leak a bit at the seal.
I'm assuming the TStat will come with a gasket....not 100% sure though...I got a STANT TStat and cap.
I'll check out the specs on the Mopar and Zerex coolant as well.
Any tricks to removing the housing and replacing the Tstat that might be helpful?
Old 13 Oct 2012, 08:25 pm
rcktpwrd's Avatar
It's only a couple bolts that hold the housing together... But it's in a cramped space, pretty much like every thing else in the PT.
Joel
www.rcktpwrd.com
flushing the radiator bogaz Tech & Performance Forum 2 20 Nov 2011 09:41 pm
flushing brake fluid bugatti Tech & Performance Forum 18 26 Mar 2011 12:27 pm
Flushing a 2004 PT Cruiser tjk3030 Tech & Performance Forum 1 27 Jun 2010 10:05 pm
Thermostat is too big??? jkdrummer Tech & Performance Forum 1 20 Mar 2009 06:02 am
Flushing Radiator KingKole02 Tech & Performance Forum 17 01 Mar 2007 02:40 pm
