Rough idle
Old 15 Oct 2012, 12:38 pm
Default Rough idle
I have a 05 pt with 135,000 miles on it. I'm getting a rough idle no accessories on. But when I give it gas it goes away. I know it's been discussed before but everything I found was low miles. I was wondering if its different because the higher miles and other stuff to look at. Let me know what you guy think. I jus replaced the plugs and wires probably around early may.
Old 15 Oct 2012, 03:34 pm
Default Re: Rough idle
my first guess would be a vacuum problem. try spraying something like brake cleaner around the areas such as intake manifold and vacuum lines.
Old 15 Oct 2012, 07:42 pm
My guess is Idle Air Control sensor or valve :-D only is used when the car is idling, so it points in the right direction :-D
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
rough idle on my 01 pt michael18 Tech & Performance Forum 2 26 Mar 2012 08:23 pm
Rough Idle badkarma76 Tech & Performance Forum 30 21 Jul 2009 07:47 pm
Rough idle 03 GT elmeyer Tech & Performance Forum 2 03 Jul 2009 09:44 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
