Thermostat housing
Like Tree4Likes
Old 15 Oct 2012, 05:12 pm
Default Thermostat housing
Help....I replaced my thermostat last year and now its leaking around the housing it sits in! The thermo I got had a rubber gasket around it so I thought I did not have to use any sealer but maybe I should? Any sugestions??? Thanks in advance.
Old 15 Oct 2012, 05:59 pm
Default Re: Thermostat housing
You can carefully check to see if the housing fasteners are still tight. If they are then you either have a fractured housing or need to replace the thermostat seal.
You are correct that a sealer in that area is not needed and since you have had a trouble free year of service sealer is not the problem.
Busted_PT and Badglas like this.
Old 15 Oct 2012, 06:07 pm
X2 on that. The housing is a common part that cracks. Available OEM or parts store.
Badglas likes this.
Old 15 Oct 2012, 07:41 pm
Yeah the housing is cheap plastic, same one thats on the neon actually. Which i have cracked with a light tap trying to unstick a thermostat.
If its not the housing, just change the thermostat again, sometimes the temp senor housing will get hot enough to warp the seal, causing a small leak :-D
Old 15 Oct 2012, 07:51 pm
After considering the time it takes to change 2 of these IMO these three things should all be changed together?
Busted_PT likes this.
Old 16 Oct 2012, 03:41 pm
UptownSport's Avatar
There's the t-stat housing and the 'connector' to the head.
The connector corrodes severely-
and as these guys have mentioned the T-stat housing loves to warp.
IF you need the connector I have one for sale on e-bay, I milled the surfaces so they're fresh;
ends tonite.
Neon 4884004AA PT Cruise Thermostat Housing / Water Outlet Water Neck Turbo Race | eBay
pluminator's right about being retrofitted on the Neon, we used to buy them new, but they've gotten downright expensive.
2002 - CHRYSLER - PT CRUISER - - L4 - 2.4L - GAS
COOLING SYSTEM / COOLING / RADIATOR & COMPONENTS / Connector
4884004AA - Connector outlet adapter
MSRP $90.45
Otherwise if it's just the plastic housing you can work it so it's not warped, buy a new one from Chrysler (Dunno about the PT, but the Stratus isn't too expensive) or i might have one laying around that's of no use to me.
Old 16 Oct 2012, 05:22 pm
<-- When putting the housing on, turn it 180 from what the picture shows.
Old 16 Oct 2012, 06:40 pm
Really!!!!
Old 20 Oct 2012, 12:07 am
Like this one?
Old 20 Oct 2012, 02:18 pm
Thanks!!
3in o2 housing mattsptgt Tech & Performance Forum 0 15 Jun 2011 05:35 pm
ok whats the trick? thermostat housing?? 02ptlimited Tech & Performance Forum 11 02 Sep 2010 06:27 pm
01 leaking from Thermostat housing, Please help gdarst Tech & Performance Forum 11 06 Jan 2010 06:52 am
Thermostat housing replacement SRT8guy Tech & Performance Forum 5 12 Nov 2008 12:43 pm
02 housing!! silver srt General Turbo Discussions 17 15 Sep 2003 10:35 pm
