2001 PT Leaking coolant
Old 16 Oct 2012, 09:35 am
Default 2001 PT Leaking coolant
Leaking coolant from front of engine (passenger side). Drips are coming from the passenger side of the block closest to the firewall. Read through some of the forums, and the radiator, cap, and thermostat look dry on the outside. Coolant is dripping, so I know there is a leak. I haven't started taking things off yet, but was trying to locate the weep hole and the water pump itself. Does someone have some pictures or suggestions on what to look for?
Have my fingers crossed for a hose, but the only hoses i see are going to/from radiator look good. I don't see the hoses for the heat.
Thanks
edit: 2.4L w/ 170,000 miles Manual Trans A/C
Old 16 Oct 2012, 03:29 pm
UptownSport's Avatar
Default Re: 2001 PT Leaking coolant
First, good you did a search before posting!!!!
Don't think I have a pic from below of WP installed on engine, but crawl under passenger's front and look up- Lower radiator hose goes to and intake pipe, which fits directly in back of WP.
Old 16 Oct 2012, 05:33 pm
I figured I was going to have to replace somthing up there, so I started taking stuff apart... Yup, the water pump is the source. There is an orangish / redish orange stains all over the place. The same color as my driveway under the PT...
So, I am going to attempt to replace the water pump and timing belt....
I've gotten the balancer off... Rented a tool from Autozone that was a touch too short. Used a bolt and drilled a pilot dimple after serveral attemps and having the bolt and dowel pin slip.
do I really need to disconnect the A/C lines?
Coolant Leaking near Tranny helpless Tech & Performance Forum 16 30 Jun 2012 06:22 pm
2001 PT leaking coolant WildBill1988 Tech & Performance Forum 20 08 Oct 2009 09:30 pm
leaking coolant near transmission pan pppt03turbo General Turbo Discussions 8 19 Feb 2008 02:14 pm
Heater hose is leaking coolant! Ctown General PT Cruiser Discussions 9 03 Aug 2006 08:01 pm
Leaking coolant line TripleJackInGA General Turbo Discussions 0 03 Oct 2003 10:00 pm
