Emergency help
Old 16 Oct 2012, 09:44 pm
Default Emergency help
I am replacing my thermostat and house bought a dorman houseing is there a torque setting to tighten that in place or is hand tight fine. I have a leaking problem and cant get it to stop leaking. The thermostat is in place like it should be. Could I have gotten a bad housing?
Old 16 Oct 2012, 09:54 pm
Default Re: Emergency help
Anything is possible. Was the surface of the metal housing smooth? Is it possible you have cracked the new housing. Also I have heard of some housings with a pin hole. Also saw a post by Uptown about the base being warped. I have no personal experiences there.
Old 16 Oct 2012, 10:03 pm
Use some fine grit sand paper to make sure the surfaces are clean. Use a torque wrench if your not sure or use a quater drive socket set if your ham fisted.
And rent or buy a coolent system pressure tester! The leak might be coming from someplace else?
Old 17 Oct 2012, 05:39 am
YES, there are specific torque settings when tightening down the thermostat housing. Definitely more than hand tightening. According to the Haynes manual:
Thermostat housing cover-to-housing bolts 110 in-lbs, 12.5 Nm
Thermostat housing-to-cylinder head bolts 20 Ft-lbs, 27 Nm
Old 17 Oct 2012, 07:37 am
i used a little permatex ultra black on mine.
never hurts.
never leaks either (:
also just fyi. i didn't remove the upper intake when i did mine. i don't understand why people tell people to do that. must be a chiltons thing.
Old 17 Oct 2012, 01:18 pm
Thank you all for all the help. To update you it was the thermostat housing that I just bought from auto zone I thought it would be ok to use that part cause it was a dorman part and generally I have herd good things about those parts. But I guess when they were making it a flaw developed and caused a 1-2 hour job take 4-5 hours. This is the second bad part I have bought from auto zone, need me to say I will only buy parts from the dealer?
Old 17 Oct 2012, 01:45 pm
What did you determine to be the flaw with the part?
emergency, pt just died on highway with key on rdpar General PT Cruiser Discussions 12 15 Aug 2012 07:28 am
PROPER USE OF THE EMERGENCY BRKE GALVANIZEDYANKEE Tech & Performance Forum 0 23 Oct 2008 01:41 pm
PROPPER USE OF THE EMERGENCY BRAKE GALVANIZEDYANKEE General PT Cruiser Discussions 0 23 Oct 2008 01:36 pm
Emergency Brake proxeyed Tech & Performance Forum 8 21 Feb 2005 12:56 pm
