Charging Issue?? Battery light on?
Old 17 Oct 2012, 12:20 pm
Default Charging Issue?? Battery light on?
the battery light on my 04 PT came on the other day..Drove it home and it finally lost enought charge to stop shifting so I limped it home..
like a dummy I went ahead and replaced the Altinator and belts,,No helped it..Battery light still on and battery gos down same deal..
anything else to check to trouble shoot? it ..I knwo its not charging I checked it with a meter..
anything else that would stop it charging? I hear the voltage regulator is in the PC? that would be my next guess?? a new PC? ..
Old 17 Oct 2012, 12:28 pm
Default Re: Charging Issue?? Battery light on?
The PCM will indicate a problem code to identify the charging problem. You would need to get your PT scanned. This information will be in memory even if you do not get a engine check light.
Otherwise throwing parts trying to correct the problem is going to get costly guessing what the charging problem is?
Old 17 Oct 2012, 12:30 pm
Ray_Dockrey's Avatar
How old is your battery? Maybe it just needs to be replaced.
Old 17 Oct 2012, 12:39 pm
^^^^^^ what he said ^^^^
Look for the oval or round small decal on the top or side of the battery that has a letter followed by a number. This would be the true shelf age of the battery.
i.e. K10 = 11th month which is November and the year 10 = 2010. November of 2010.
Old 17 Oct 2012, 02:33 pm
mikelikestobike's Avatar
Places like AutoZone and Advance Auto will test the battery and charging system for you for free usually I think. Their machine can tell if the battery is holding a charge and if the alternator is properly charging...
Maybe you already did that and I missed it... if so forgive me.
'03 Manual non-turbo in Silver w/ Factory flames.
K & N Drop in, Modded airbox, MSD Superconductor wires, Strut bar, blue dots in taillights. Sold 12/13
Old 17 Oct 2012, 03:32 pm
...x4
Old 17 Oct 2012, 03:54 pm
batterys not even a year old..charges up great but of course runs down as you drive it..I did a test with a meter off the jumper post and ground to the chassie with it running no voltage at all..battery test ful charge afte rI charge it with a charger?...
I thought it could be a bad battery dead short? amy other ideas?
Old 17 Oct 2012, 04:16 pm
Charging up a battery is not a conclusive way to checks its condition. But as you are showing negative voltage charge to the battery then re-read post #2.
Sorry!
Old 17 Oct 2012, 09:26 pm
thanks its not throwing a code on the dash or with my hand held code reader? will i have to take it to adealer to get a better read of the code? or should my hand held find it? would a hand held from autozone do any better?.
thanks
Old 17 Oct 2012, 09:32 pm
Have you traced your cables down and cleaned the connections all the way back to there source. There is a big ground on the inner finder near the battery.
Seconday Battery, Charging issue, Amp, Sub Busa_Powered Sound and Security Forum 20 12 Sep 2012 03:01 pm
Charging Issue Solved Many Thanks!!!! RMoore Tech & Performance Forum 0 27 Aug 2012 04:31 pm
01 Charging system/battery/alternator Issue NicoleW Tech & Performance Forum 6 13 Feb 2012 10:43 pm
battery issue misa85 Tech & Performance Forum 1 27 Dec 2011 11:46 am
Charging system battery voltage DJmart Tech & Performance Forum 19 14 Sep 2011 11:26 pm
