PT Cruiser Won't Start
Like Tree2Likes
  • 1 Post By Busted_PT
  • 1 Post By rcbuckley
Old 18 Oct 2012, 03:31 am
Default PT Cruiser Won't Start
I bought my 2002 PT Limited a week ago from a private seller. Runs great but the last couple of days, it has started acting funny when I go to start it. I put the key in and the dash lights up but when I turn, nothing happens and all the dash lights go off. Tried shifting into neutral and back to park and everthing engaged and it starts fine but the clock reset as if the battery had become disconnected. Now every once in a while this repeats but other times it starts just fine. Tonight, it happened again but moving the shifter isn't working this time and I'm getting nothing?? No dash lights, won't even try to start. Please help.
Old 18 Oct 2012, 03:38 am
ROCKETMAN8060's Avatar
Default Re: PT Cruiser Won't Start
Start by checking the battery cables or maybe your battery is bad!
ROCKETMAN8060
Old 18 Oct 2012, 05:56 am
Also could have a intermittent charging from worn brushes in the alternator. But do the above and a charge first.
ROCKETMAN8060 likes this.
Old 18 Oct 2012, 10:07 am
So here's the update. Tried to jump the cruiser and it started. Battery light came on but it ran for about 15 minutes then died. Tried to jump it again and it would turn over but as soon as I tried to disconnect the jumper cables, the engine died. Waited a bit with the cables in place with the booster car running and tried one more time to start it and it started. After letting it run for about 5 minutes, I disconnected the cables and it stayed running. This time the battery light was not on and it ran for about 20 minutes until I turned it off. It almost seems like there is a loose wire or connection somewhere in the car, hence the dash lights flickering on/off when I jiggled the shifter before.
glenwood52 likes this.
Old 18 Oct 2012, 10:28 am
Posts #2 & #3
Old 18 Oct 2012, 11:08 am
Get a new battery. Check the condition of the wires, look for corrosion on both ends of both cables.
Old 18 Oct 2012, 12:09 pm
At least have the battery load tested. But they're is some other issues as well or it would run off the alternator after a boost. Connections and such. The ignition wires in the column can also cause the fiicker. Rule out everything under the hood first.
04 cruiser won't start!! HELP PLEASE!! sconnors11 General PT Cruiser Discussions 15 03 Jun 2014 06:37 am
06 PT Cruiser won't start BUT.. jennjewelz Tech & Performance Forum 5 29 May 2012 06:43 pm
PT Cruiser will not start Bone Tech & Performance Forum 12 10 Jul 2011 09:04 pm
Cruiser won't start veracruise Tech & Performance Forum 5 18 Jun 2011 12:24 am
04 Cruiser ran out of gas, now will not start? Leannaluv General PT Cruiser Discussions 2 11 Nov 2010 11:07 pm
