Weird noise when engine revs
Old 19 Oct 2012, 05:36 pm
Default Weird noise when engine revs
'o1. Motor sounds good at idle, until you rev it up. Then it makes a noise, almost like a bearing spinning. This noise goes on until I turn the a.c. on. Turn ac off, noise back. Standing over motor, sounds like it's coming from the top, but I wanna believe it is the compressor. Any ideas?
'01 Silver Limited Edition
No Mods,Yet!
Flip-Out DVD, 12"Kenwood Sub,800w Kenwood Amp
Old 19 Oct 2012, 08:07 pm
TurboDucky's Avatar
Default Re: Weird noise when engine revs
Could be the compressor. You can take that belt off and run the engine. That would help "eliminate the unknowns"
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Old 20 Oct 2012, 02:19 pm
UptownSport's Avatar
I'd think your description is enough to narrow it down!
Weird rumbling noise in dashboard when I turn over the engine/ turn off the engine... thinkinboutit Tech & Performance Forum 5 22 Jan 2014 08:23 pm
Engine Revs and then dies at start Chas777 Tech & Performance Forum 3 12 Jun 2011 06:53 pm
Engine revs up automatically ProDigit General PT Cruiser Discussions 2 07 Feb 2011 07:09 pm
Engine revs while idling when air or heat is on mags593 Tech & Performance Forum 2 14 Apr 2010 09:34 pm
Weird Noise coming From Engine LVActor Tech & Performance Forum 11 08 Jul 2008 02:07 pm
