Caliper woes... Brake help requested.
Old 20 Oct 2012, 08:39 pm
Default Caliper woes... Brake help requested.
So the past week or so when I start off, my brake pedal goes all the way to the floor before it stops. I'll pump it a few times and it gets normal. Air in the lines, simple enough. But, after about 20 minutes driving the brake pedal gets really firm and extremely sensitive and something wasn't letting go, meaning I felt like I was driving with my parking brake on. I would get a definite jolt (as if I hit the pedal) when I would coast to a stop.
I pulled the wheels today and replaced the brake pads. The outside pad on the front passenger side (front disc, rear drum) was worn way down to the point of rubbing on the rivet, although the rest still had a lot of life. I compressed the calipers, replaced the pads and took off down the road.
Thought everything was fine until pulling back into my driveway where I felt the same jolt and saw a load of smoke billow out from under my wheel well. I'm thinking the caliper is sticking internally. Replace the caliper. Does that sound like the right avenue to explore?
Old 20 Oct 2012, 10:54 pm
compdr59's Avatar
Default Re: Caliper woes... Brake help requested.
Did you check the caliper slides? That is the typical cause for uneven pad wear . There may be rust build up inside the caliper. A rebuild kit is cheap. Flush the brake fluid too.
Original Owner 135k
Need to replace front brake caliper tubularbel General PT Cruiser Discussions 7 20 Sep 2011 02:06 pm
PT GT Brake Caliper Question 2005PTGT Tech & Performance Forum 5 29 May 2010 10:11 am
What Brake Caliper Color? amazingarthur Exterior Accessories Forum 21 29 Jul 2004 11:20 pm
Red G2 Brake Caliper Paint Set 4 Sale! yobiebs Vendors & Buyers Forum 2 03 Nov 2003 05:18 pm
Brake Caliper Paint? PTRON General PT Cruiser Discussions 3 17 Feb 2003 02:11 pm
