Radiator leaking coolant.
Like Tree2Likes
  • 2 Post By Kawizx9r
Old 21 Oct 2012, 11:50 pm
Question Radiator leaking coolant.
Not long after fixing my trans fluid leak I noticed my car has been slowly losing coolant. I took a peak underneath the car and found that its coming from the radiator itself. I'm thinking of buying stop leak for it first to see if that works but I might end up just replacing the radiator all together. My question is should I buy the stock radiator or buy an aftermarket high performance radiator? I plan on heavily modifying my PT GT and wonders if a high performance radiator would benefit my car or should I just stick with the stock radiator?
Purple 2005 PT GT ATX w/ Mopar stage 1 PCM, Diablosport 93 oct tune, airbox mod, K&N drop in filter, Mopar BOV, AGP wastegate (8 psi spring), Custom made stage 1 camshafts, motor mount inserts, NGK Iridium plugs, MSD wires, ARP Head Studs, Gates Racing Timing Belt, AC Delete kit, purple painted Valve cover, Rebuilt (stock) Turbo , AEM Boost, Oil Pressure, and Wideband guages, triple guage A pillar pod, Strut Tower brace, Needswings 3in o2 housing, 3in downpipe w/ high flow cat and electric cutout, 2.5in Magnaflow catback, custom check valve, custom larger capacity trans cooler w/ built in cooling fan, Eibachs pro lowering springs, KYP front and rear struts, matte black hood and grille, gloss black stock SRT neon rims, purple lug nuts, blacked out tailights and reflectors so far. Built and bored out motor, AGP S256 turbo, ported cylinder head, and built trans soon to come.
Old 22 Oct 2012, 12:01 am
Kawizx9r's Avatar
Default Re: Radiator leaking coolant.
Stock replacement will suffice; even heavy modding won't require a bigger radiator. There were some heavy, heavy, modded PT's and all stuck with their stock radiator.
If you do a simple google search, you'll find my complete walk-through with pictures on how to replace the radiator. Done it several times so I'm very familiar with it if you've got any questions.
Kawi is a friggin genius!
Old 22 Oct 2012, 12:14 pm
Talking Re: Radiator leaking coolant.
Cool, thanks Kawi.
Old 22 Oct 2012, 12:30 pm
Unless you plan on rebuilding the engine, i'd say stay clear of the stop leak stuff. It worked good in the old days but today you run the risk of blocking up the water passages. A GT radiator from Radiators4less was $89 shipped to my door in 2 days.
BTW, i was lucky. I DID use the Barrsleak without issue so far. But it was before i read a few horror stories of blocked water passages.
Either way, GL with your decision
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 25 Oct 2012, 08:05 pm
Ok good to kno thanks!
Old 26 Oct 2012, 03:23 pm
mdfrodolives's Avatar
My stock radiator has gone on for nine years with no leaks. Of course, I used HOAT coolant--although I waited 7 years to change it.
Still, no leaks--and it cools the engine.
Now ... the fan is another issue ....
Tim
Old 26 Oct 2012, 09:03 pm
Yea my radiator is the original radiator on my PT which now has 74,500 miles on it. 4,000 miles on the new rebuilt motor and 2,000 miles on the rebuilt turbo. Haven't had any issues with the fan tho. Thank god lol
Old 26 Oct 2012, 11:13 pm
Kawizx9r's Avatar
How to; Remove Radiator
OurPTGT and NicksCruiser like this.
2001 PT Leaking coolant PTCommuter Tech & Performance Forum 2 16 Oct 2012 05:33 pm
Coolant Leaking near Tranny helpless Tech & Performance Forum 16 30 Jun 2012 06:22 pm
2001 PT leaking coolant WildBill1988 Tech & Performance Forum 20 08 Oct 2009 09:30 pm
leaking coolant near transmission pan pppt03turbo General Turbo Discussions 8 19 Feb 2008 02:14 pm
Leaking coolant line TripleJackInGA General Turbo Discussions 0 03 Oct 2003 10:00 pm
