pt tries to start and does after long time cranking
Old 22 Oct 2012, 08:13 pm
Default pt tries to start and does after long time cranking
newer plugs and wires two cans of sea foam.......and still takes a long time to start.......once it does it runs like a charm......any ideas out there.......love this car.....by the way no codes.....
Old 23 Oct 2012, 05:29 am
Default Re: pt tries to start and does after long time cranking
How about some more information? Battery condition, putting out a full 12V? What's the fuel pressure at the Schrader valve? Should be between 53 and 63 psi. What gap are you using on your plugs?
Old 23 Oct 2012, 06:52 am
Vlefaive's Avatar
The fuel grade makes a difference too sometimes... There's a reason the chunky octane the Iranians are selling under the table isn't very popular here in Canada.
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 23 Oct 2012, 09:31 am
Also, turn key to "on" before start and leave it there for a minute, then go to start - gives the fuel pump a chance to pressurize the system.
Old 23 Oct 2012, 03:13 pm
using 40 gap on plugs.....dont know pressure on fuel pump.....will see bout getting it checked.......i do buy 87 octane .....was thinking about upgrading....to higher octane......turns over good.......thanks for the help guys.....
Old 24 Oct 2012, 12:18 pm
Had the same issue intermittantly on my 2007 non turbo. My battery was wearing out. No lights or chimes but when i checked it with a voltmeter, it got down to 11.9V after sitting for a few hours (even when disconnected from the vehicle).
New battery, no more long crank.
Old 26 Oct 2012, 05:22 am
one more detail....when it does start it seems to run on 2 or 3 cylinders for 10 or so seconds......thanks for any ideas
Old 26 Oct 2012, 09:07 am
Get it running "jump it if you need to" then check the battery with a DVOM, it should be putting out at least 13 volts. If it is then your charging system should be OK.
If so then it's probably the "battery cables" !
As to running crappy hook up a vacuum gauge to get an idea on engine condition. You can do a You Tube search to see how to read one, they hook up to manifold vacuum.
Old 27 Oct 2012, 03:02 am
thanks for the help chip will check when i get home.....today.....
10 Degrees Out, Cranking but no start stixboy General PT Cruiser Discussions 21 17 Feb 2011 09:36 pm
Long time no see RNCRUZR General PT Cruiser Discussions 2 05 Feb 2011 11:47 pm
long cranking 4b316 Tech & Performance Forum 3 05 Aug 2008 07:34 am
Been a long time: Upgrading to GT PT wunderboyblue General Turbo Discussions 6 30 May 2004 11:05 pm
