high idle after fuel additive
Like Tree3Likes
  • 1 Post By Busted_PT
  • 1 Post By NitroPT
Old 24 Oct 2012, 03:42 pm
Default high idle after fuel additive
Put some redex fuel additive in my 2003 pt cruiser when I last filled up with fuel. Towards the end of the tank it developed a high idle 900 - 1000 (also slow to drop). No engine code when checked. No faults on vacuum pipes so changed idle air control valve and cleaned throttle body but problem continues. Car was running fine before additive. I wonder if it has damaged the upper O2 sensor but not enough to trigger fault code.
Any ideas as at a loss.
Old 24 Oct 2012, 04:40 pm
Default Re: high idle after fuel additive
Not familiar with the product you are using?
Many fuel additives can make the engine run slightly richer.Also some may coat the 02 sensor. The bottle should say if it is sensor safe or not?
Either way if filling the tank which dilutes the effects does not cure your problem then it may something else and only coincident related to time of the additive use.
Old 24 Oct 2012, 05:21 pm
Just go to the next box.
NitroPT likes this.
Old 24 Oct 2012, 05:25 pm
Try oiling the pivot points of the throttle linkage and check the cables to see they are working free. Lastly I would check the vacuum lines. I'm no sure if this would cause a code. One more thing if all else fails remove the inlet hose on the throttle body and inspect the blade is closing all the way.
NitroPT likes this.
Old 24 Oct 2012, 05:29 pm
Is this how you get more "likes" count up by posting the same thing twice?
Good points though Mr.D !
Busted_PT likes this.
Old 24 Oct 2012, 05:37 pm
Gave you a refund on the like!
Old 24 Oct 2012, 08:10 pm
I think its a coincidence.
You could probably put a gallon of jet fuel in it and not raise the idle 100rpms.
Old 24 Oct 2012, 08:13 pm
Wow this has to be the quickest "I got a problem, I'll replace a part" post I have ever seen! That's going to be a real expensive way to maintain a vehicle!
Welcome aboard new guy!
Old 24 Oct 2012, 10:43 pm
considering what JP4 and JP5 is I don't know about that? Maybe -100rpms
Most all fuel additive=
High idle after spark plug change MrBeefy Tech & Performance Forum 7 02 Oct 2012 06:48 pm
High idle 2001cruising Tech & Performance Forum 17 12 Sep 2012 09:17 am
High Idle and Cooling issues shadowsnkx Tech & Performance Forum 0 06 Sep 2011 08:55 pm
2003 MT High Idle Sturdevant General Turbo Discussions 6 11 Sep 2007 09:55 pm
Race fuel additive..Octane mopar2ya Turbo Performance 0 10 May 2004 09:37 pm
