Radiator Leak + timing belt kit
Old 25 Oct 2012, 06:53 am
Default Radiator Leak + timing belt kit
I have a leak at the top left (driver's side) of the radiator. I'm not exactly sure where the leak is, but it is dripping from the top along the seam just below the plastic and down near the battery. Before I order a new radiator, would this type of leak be repairable.
Also, if I am going to pull the radiator, I will go ahead and do the water pump and timing belt at the same time. Can anyone comment on this type of kit from ebay.
97-02 Plymouth Dodge Chrysler 2.4L DOHC Timing Belt Water Pump Kit VIN "X" "B" | eBay
Old 25 Oct 2012, 10:47 am
Default Re: Radiator Leak + timing belt kit
don't know much about the radiator except it is plastic bonded to metal. don't think it's repairable. i could be wrong.
many people here get the timing belt kits from rockauto.
wait a bit and someone will chime in with more info. you can also check the how to section. there might be more info there.
Old 25 Oct 2012, 11:16 am
Thanks for the added info. I figured that the radiator would need to be changed. I just checked Rockauto, there are several options. Can anyone comment on which timing belt kit (with waterpump) to get, or to avoid?
Old 25 Oct 2012, 05:14 pm
I had my radiator leak from the exact same location in both of my cruisers. It was cracked at the top right behind the battery and would spray onto the battery blanket when warmed up. They seem to split when you give them a funny look had to replace mine.
As far as the timing belt many people go with the Gates kit from rockauto. Belt pump and idler. Ill need to be doing mine soon as well. Though I may buy the parts and have it done elsewhere don't really feel like dealing with it.
Good luck!
- Guy
Radiator Cap Leak Mikeliny General PT Cruiser Discussions 8 08 Oct 2017 10:20 am
Poor gas mileage after changing timing belt, water pump and radiator??? fduffy28 Tech & Performance Forum 0 02 Apr 2011 04:05 pm
Coolant Leak - Timing Belt hdave Tech & Performance Forum 2 16 Dec 2009 05:58 pm
RADIATOR LEAK TOP?? mjb457 General PT Cruiser Discussions 0 20 Apr 2009 10:05 am
