anyone know what this is?
Old 25 Oct 2012, 09:41 pm
Default anyone know what this is?
So i got my heating/cooling issue all taken care of and my 03 2.4 non turbo is running at normal temp.
However a new issue has come up.
I cannot use defrost :/ Well i can.......however turning the defrost on causes my cars idle to go from normal "which took me 3 months to achieve" to RPM's dropping to around 350-400 and causing a terrible shake. Which in the summer would be fine because i dont use defrost then....
However with winter fast approaching, i'm most certainly going to need the defrost function for the windshild :-D
Now i know that the defrost function is somehow tied into the AC pump, could a bad AC pump cause this? Or is the tensioner on my powersteering/AC belt just lose as heck?
Any sugguestions would be greatly appriciated
Old 26 Oct 2012, 12:10 am
UptownSport's Avatar
Default Re: anyone know what this is?
I suppose pump could be bad, but turning on AC (without the idle valve responding correctly) with no faults would cause about this much idle drop.
Old 26 Oct 2012, 07:47 am
The ac function should cause this same issue though. Then I would check that the fan is running and if so maybe clean the IAC and see if that helps.
Old 26 Oct 2012, 03:20 pm
mdfrodolives's Avatar
Your fan is not cooling your A/C "high side" pressure. "Defrost" is actually using your A/C to pull moisture out of your car's interior. So turning on defrost is like turning on your A/C.
Considering the "shakes and shimmies", it sounds like the fan.
Check both high and low speeds on the fan. There's a "sticky" on it.
Tim
Old 29 Oct 2012, 07:53 pm
alright ill try that once this hurricane is over with haha. Also the RPM's drop when i turn on the rear defrost :/............which tells me alternator but i tested it and its fine. batterys good too. This car just has its tiny quirks lol
