Throttle body spacer
Like Tree3Likes
  • 2 Post By NitroPT
  • 1 Post By UptownSport
Old 26 Oct 2012, 04:28 pm
Default Throttle body spacer
I see several of the accessory sites have them and claim all kinds of performance increases.
Snake oil or has anyone actually seen a difference n low end torque?
Old 26 Oct 2012, 04:53 pm
Default Re: Throttle body spacer
Throttle Body Spacer?
Old 26 Oct 2012, 05:07 pm
I don't use them.....
Is that thread a sticky? It does seem like it would be a prime newbie question.
I liked Crewzings, buy one and pick a side answer!
Old 26 Oct 2012, 08:19 pm
I found a site that has a BOGO sale on TB spacers, but dayum I can't remember the link....lmao....
Old 26 Oct 2012, 09:48 pm
soonercruiser's Avatar
Thumbs down Re: Throttle body spacer
SNAKE OIL!
Do you use any snake oil?
Frank, aka SOONERCRUISER,
Old 27 Oct 2012, 12:45 am
Originally Posted by soonercruiser View Post
SNAKE OIL!
yes it works great on foot fungus, hair loss, bad breath, and carbon buildup on the tail pipe.
Old 27 Oct 2012, 01:55 pm
UptownSport's Avatar
Ok, place an order for three for me
Old 28 Oct 2012, 03:48 pm
On Nissan forums there are a lot of folks who swear by spacers. Not because they "swirl" the air, but because they do not conduct heat so the throttle body stays cooler. Still seemed bogus to me, if it increased performance much the mfg'er would do it at the factory level.
Old 28 Oct 2012, 04:41 pm
N/A manifold is plastic, I'd say no heat would be conducted, and even if so the TB doesn't have a float bowl ...
and TB length is so short it couldn't possibly heat intake charge significantly ...
PT's plenum was chosen because it's a (rather) small engine to move a big, possibly overladen, vehicle. We'll talk about factory options for same engines in a compact in a bit.
Linked explainations make sense theoretically to some extent;
First, one for a carb (Dominator, AFB etc.) would massively increase plenum area, AND smooth any turbulence. a V-8 had next to no plenum, more at: a 'junction' area- You can see an factory race one here (google) with a larger plenum still isn't as large as the stock PT:
You could see how much volume a spacer would add:
Plus, PT doesn't have bends;
So you could see a 2.125" spacer an inch long wouldn't add much volume.
Next, look at other factory manifolds for the PT engine;
the 2.0 DOHC has a very large plenum;
(this is only ~ 3/4 of it)
And you could buy plenum spacers at one time for that 2.0 manifold; massive increase in area:
Here's the dyno, not too much even if you do believe it:
A swirl is absolutely stupid- You want the charge to be absolutely smooth in plenum- It needs to be coaxed into individual runners-
air moving at any velocity won't want to flow where you want it!!!!
Plus, does anyone believe after passing thru plenum, entering runner, traveling twenty some inches, going past intake valve there'd be any swirl remnants????
In short spacer volume is insignificant and swirl (if it actually would add swirl) is silly if not detrimental.
If you're still not convinced, I'd be glad to make one if you want to send chunk of Alumium
Originally Posted by Dino View Post
Throttle body spacers are aftermarket devices that purport to increase horsepower in a variety of ways. The efficacy of this modification depends largely on the engine it is applied to and the engine's factory shortcomings.
Placement
TB Spacers are designed to be placed between the throttle body (the large butterfly valve that controls airflow into an engine) and the intake plenum onto which it is bolted.
Marketing
According to manufacturers, TB Spacers make power through better fuel atomization, which is accomplished by creating a "tornado-like" swirl in the intake manifold.
The Tornado Effect
Air-swirl effects tend to benefit engines with throttle-body injection more than those with multiport injection, since multiport systems use a dry intake manifold that does not contain any fuel droplets to atomize.
Plenum Effects
Throttle Body spacers make the majority of their power by increasing the volume of space between the throttle body and intake runners. This gives the engine more unhindered air to tap under high-demand situations.
Cost and Consequence
Throttle body spacers are worth a few horsepower on some older cars, and those newer multiport systems that came from the factory with an under-sized plenum. Bear in mind, though, that a $250 billet-aluminum spacer probably isn't going to make much if any more power than a $35 plastic one.
Answer
Throttle body spacers are a prime example of modifications that work quite well on some cars and not at all on others. The efficacy of this simple mod depends largely upon the engine, and the extent to which it has been otherwise altered.
Location
TB Spacers fit in between the throttle body (main air valve of the engine) and the intake manifold plenum (the large space behind it).
Theory
Along with throttle body flow, an intake manifold's plenum size determines the reserve of air that an engine can call upon when required. A large plenum is crucial to making top-end horsepower.
Function
By moving the throttle body a little further out, a spacer can increase plenum size by as much as 20 percent on some cars.
Effectiveness
On unmodified, fuel-injected engines with sufficient plenum volume, many customers report that TB spacers make little to no difference in power.
Modified Applications
On engines internally modified for increased airflow (camshafts, larger valves, ported cylinder heads), throttle body spacers can make a crucial difference in power production.
Answer
Location
Theory
Function
Effectiveness
Chromenut likes this.
Throttle Body Spacer? Dino Tech & Performance Forum 12 14 Aug 2010 12:05 pm
Throttle body Spacer partyd Tech & Performance Forum 6 24 Apr 2008 03:59 pm
Throttle body spacer? 1lowufo Tech & Performance Forum 5 23 Mar 2005 09:50 pm
Throttle Body Spacer PT-ERA Tech & Performance Forum 19 06 Jan 2004 03:06 pm
Throttle Body Spacer CHRUZIN Tech & Performance Forum 7 19 Nov 2002 11:53 pm
