Mopar "Camshaft Position Sensor", or aftermarket?
Old 26 Oct 2012, 07:56 pm
Default Mopar "Camshaft Position Sensor", or aftermarket?
Looks like we're going to need one of these after all (cleaned the connection last week, but the CEL came on again, with some sputtering this time). Is the Mopar unit the best, or is there a suitable aftermarket one?
Old 26 Oct 2012, 08:16 pm
Default Re: Mopar "Camshaft Position Sensor", or aftermarket?
Personally, for sensors of this type I would not suggest using anything aftermarket. I've never used aftermarket sensors but have spoken with several acquaintances who have and they never lasted more than 12 months. Just my suggestion/opinion...
Old 27 Oct 2012, 12:46 am
Thanks Chromenut.
Old 28 Oct 2012, 12:02 am
To my surprise, our local dealership parts dept was open today (Saturday). The CPS was $61.25 (plus tax). Installation was a breeze, in fact, one of the easiest things to replace on this car.
One question I have though, is there anyway to clear the computer code/s without having to disconnect the battery every time? I'm getting tired of having to reset a bazillion things on our aftermarket stereo.
Old 28 Oct 2012, 03:17 am
Taking off the negative battery cable is the only way when your doing it yourself without a scanner from the dealer or mechanic or one that you can pick up at an auto store or ebay.
Here's the eBay page with the scanners. Not too expensive.
obdii scanner | eBay
Old 28 Oct 2012, 09:37 am
2step's Avatar
The code is "stored" in the PCM memory only for a short few days. This is so mechanics can retrieve it when an owner shows up with a possible problem. I believe the code will clear itself after a certain amount of re-starts if the cause has been removed or fixed.
Old 28 Oct 2012, 10:22 am
From PT Do-It-Yourself.net:
On the majority of vehicles manufactured prior to 1996 disconnecting the battery could erase fault codes, at least temporarily until the code resets and turns the check engine light back on. On newer vehicles, the PCM's fault codes are stored in a "nonvolatile memory” that is stored if the battery is disconnected. The codes remain intact until they are cleared using a scan tool.
So, if I'm reading this right, it sounds like you can get rid of them with disconnecting the battery but not permanently until a scan tool wipes them away.
Old 28 Oct 2012, 11:49 am
When I installed the new sensor yesterday, I didn't disconnect the battery. When I backed it out of the garage the CEL stayed on (and the car bucked for a second). I then disconnected/reconnected the battery and re-cranked and the light went out.
We're going to drive it to town today to make sure everything is working alright. I'm definitely going to get one of the scanning tools, thanks for the tip on those.
Old 28 Oct 2012, 12:18 pm
That's a good price on that CPS, here in the Seattle area 3 different dealers quoted me approx. $80.50. I've read many posts on PT Cruiser problems while trying to diagnose my own, and every post I've read recommended the Mopar CPS including a service tech who said that is the one sensor he NEVER replaces with an aftermarket brand on a PT.
Normally it takes a few days for the check engine light to turn off by itself after a repair, and 40 to 50 restarts and a certain number of "drive cycles" before the trouble code clears. I recommend putting an OBD2 scan tool on your Xmas list. It makes retrieving trouble codes easier on ALL cars made after 1995 and allows you to clear the codes from the computer immediately (without having to reset your clock and radio presets every time the battery is disconnected). This is very helpful when diagnosing problems and when wondering if that $50+ sensor you just replaced was actually the source of the trouble code being set. Often times it's not unfortunately.
camshaft position sensor (CMP) hobbyman Tech & Performance Forum 62 01 Aug 2015 12:43 pm
camshaft position sensor hokiecruiser Tech & Performance Forum 16 01 Nov 2012 05:14 pm
Camshaft Position Sensor ejschultz Tech & Performance Forum 6 22 Sep 2010 09:58 pm
Camshaft Position Sensor kghaddon Tech & Performance Forum 5 02 Jun 2009 10:09 am
