Ck Eng Light
  • 1 Post By alanrw
Old 26 Oct 2012, 10:18 pm
Default Ck Eng Light
Got one today. Did the key dance and it came up P1294:
Target Idle Speed Not Reached Conditions: DTC P0106, P0107, P0108, P0121,
P0122 and P0123 not set, engine started, running at idle in Drive or Neutral, and
the PCM detected the Actual idle speed was more than 200 rpm over or more
than 100 rpm less than the Target speed for over 14 seconds. Possible Causes:
Engine vacuum leak in a hose, brake booster or in the engine IAC motor control
circuits open or grounded in the wire harness Throttle body dirty or restricted
(trying cleaning it and retesting) linkage or throttle plate not in the
correct position PCM has failed
Anyone dealt with this one before? Additionally, the last few days have experienced hard downshift when coming to a stop (automatic tranny). Any ideas?
Is there a vacuum hose from the engine to the AT?
thanks
alan
Old 27 Oct 2012, 02:29 pm
Default Re: Ck Eng Light
Hose between the manifold and throttle body had a thumb sized hole in it. Problem solved.
alan
Busted_PT likes this.
Old 28 Oct 2012, 12:24 pm
Thanks for posting the solution to your problem, it helps others.
Old 28 Oct 2012, 03:44 pm
Any idea how the hole got there?
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Brake Light Condensation/Tail Light Replacement? NewPTCruiserInPA Tech & Performance Forum 3 23 Jul 2012 09:05 pm
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
