Manual 2001 Cruiser won't star, intermittent
Old 28 Oct 2012, 12:20 pm
Default Manual 2001 Cruiser won't star, intermittent
Had some problems with it starting here and there, gradually getting worse and worse with the no-starts. Now it won't start at all.
No crank
All lights come on in the dash like it's ready to start
Battery is good
Last time we got it to start was a few days ago, thought we fixed the problem, shut it off and haven't got it to start since.
Was thinking it has to do something with the clutch interlock switch. Tested for continuity in the connector and I can't seem to get any. Test light will not light up at all.
Sound familiar to anyone at all?
Old 28 Oct 2012, 12:26 pm
jrbsr05pt's Avatar
Default Re: Manual 2001 Cruiser won't star, intermittent
when yout turn your key over to the on position do you hear your fuel pump buzzing? if so that's take that out the question. if you don't hear it then that very well maybe your problem.
2005 n/a 5 speed. 177365 miles. spectre cold air intake, white and pink leds under dash and back seats, purple leds in vents, wall with 1 18" subwoofer built behind back seat(soon to be either 16 American bass vfl8's or 4 18's with the wall rebuilt all the way to behind the front seats,cant wait!!!), blue dash lights, pink turn signal indicators. 3D tails and tinted backup lights. Power antenna (that no longer has power ha!) another one gone but wont be forgotten
2003 gt turbo. 130245 miles. autostick, mopar riceplate, 3" o2 housing and downpipe. custom diablo tune (totaled, gone but not forgotten)
2003 dream cruiser. autostick, mopar body kit, mopar bov, cai. s1 injectors. mopar s1 pcm. 3" 02 housing and downpipe installed from last turbo, upper IC hardpipe more on its way soon.......... diablo tuner in the near future.
Old 28 Oct 2012, 12:28 pm
Oh yeah, I can hear my fuel pump come on.
Old 28 Oct 2012, 01:10 pm
Try tapping on the starter while someone turns the key. If that works get you a new starter.
Old 28 Oct 2012, 01:35 pm
Hmm no power to the clutch safety switch? That sounds kinda odd but.. on my Toyota's I pulled the connector for the safety switch and jumper them with a paper clip.
I tested it with a 12 volt test light, can't remember what it did? But it had been my problem on my mini Truck, that fixed it.
Did the same thing on the Tercel just cause I could..only started it in gear once and almost hit the wall!
German cars in 1989 anyway don't have a neutral safety switich...guess the Germans figure if your not smart enough to make sure the car is in neutral...then you should not be driving anyway!
But jump it if you have to check battery for 13 volts and if it's good...then look at...Battery Cables!
Old 28 Oct 2012, 01:43 pm
I actually jumped the started, started clicking but won't crank still, did this while another person hit it with a hammer.
Talk to a Chrysler tech, said jumping the starter without depressing the clutch still won't start it. Doesn't make sense to me haha.
Old 28 Oct 2012, 02:28 pm
Have you checked the big ground behind the air filter box?;
Old 29 Oct 2012, 01:39 am
Pull your battery out and have it tested. It could have a bad cell which would prevent enough amperage to crank engine. If the battery has a dead short the car won't turn over even when trying to jump start it, but could provide just enough power to light up your dash lights. I've had this happen to me on other cars.
Also, make sure your battery connections are clean including the ground connections to the car.
Service Manual for 2001 PT Cruiser ceil99 Tech & Performance Forum 14 10 Jul 2012 11:08 pm
2001 PT Limited Owners Manual Lojo61377 General Turbo Discussions 1 26 Sep 2011 10:15 am
P T Cruiser Haynes Manual 2001 thru 2003 ItBeMe Classifieds: For Sale/Trade 9 26 Jun 2010 01:42 pm
2001 PT manual not shifting when running dgb General PT Cruiser Discussions 9 27 Apr 2010 11:35 am
FS:2001 Factory Service Manual GTP Classifieds: For Sale/Trade 2 08 Dec 2009 02:15 pm
