Error code
Old 31 Oct 2012, 03:04 pm
Question Error code
I have an error code 0633 when my check engine light comes on....but, I have searched the forums for what this code means to no avail. Does anyone know where I can find out what that code means or can someone tell me what it is?
Thanks
Ps...I'm new to the forums
Old 31 Oct 2012, 03:47 pm
Default Re: Error code
according to someone in srt forums:
edit: i just looked it up and p0633 means you have a staged pcm. it wont hurt anything and the car should run just fine with it. if you want it to go away then you will have to see the dealership and have them flash it.
maybe someone else will have a better answer.
Old 31 Oct 2012, 05:18 pm
To read:
Stage 1 kit question
another MIL code as my PT was a haulin..
Old 31 Oct 2012, 05:25 pm
Thank you for your reply's. I called Pep Boys to ask another question and I mentioned the code and he told me that it stated that the key and the pcm are not matched up correctly I talked to the dealer and they gave me the a typical dealership answer; long drawn out and way to many possible reasons they need to charge me an exorbitant of money to fix it.
Tags
check engine light, error codes, trouble codes
Thanks for error code help mycar Tech & Performance Forum 3 11 Aug 2012 07:25 am
Error Code bus b8 or 68, not sure. richardbradley Tech & Performance Forum 2 18 May 2010 07:45 pm
Error code 601 COOLSILVER02NV Tech & Performance Forum 7 14 Jul 2009 10:52 am
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
Error code??? russ00001 Tech & Performance Forum 0 29 May 2007 04:24 pm
