05 turbo...large oil leak
Old 02 Nov 2012, 10:12 am
Default 05 turbo...large oil leak
Over the past month or so I found several small drops of oil (about 10) took the car in and had the valve cover gasket, upper intake gasket, PVC valve, vacuum line and cam sensor replaced. When I got the car home there were large drops of oil on the ground and I was about a quart low. Cleaned the engine off with degreaser to see if I could see where the leak was coming from... Added oil and parked over a large piece of cardboard. This morning as I backed out of the garage there was a large puddle of oil all over the cardboard. Seems like from the center of the car. Any ideas where this is coming from? The oil filter and plug are intact....
Old 02 Nov 2012, 11:22 am
UptownSport's Avatar
Default Re: 05 turbo...large oil leak
oil pressure sensor
Old 02 Nov 2012, 12:04 pm
Thank you Uptown for the quick response hopefully that is all it is and nothing major....will post the outcome this afternoon
Old 02 Nov 2012, 01:41 pm
X2 on that!!!
Turbo oil return line leak littleblueGT General Turbo Discussions 7 24 Apr 2016 10:29 am
Oil feed line leak to turbo PTCruisinTurbo General Turbo Discussions 1 30 Dec 2013 01:31 pm
Stock Turbo, wideband, and leak tester Kawizx9r Classifieds: For Sale/Trade 1 13 Jun 2011 01:23 pm
turbo water tube leak PRIMOX General Turbo Discussions 1 19 Jul 2009 04:32 pm
P0455...large leak detected in evaporative purge system Gabriella Tech & Performance Forum 4 24 Jul 2008 08:03 pm
