pt wont start? ignition lights remain on.
Old 04 Nov 2012, 06:49 pm
Default pt wont start? ignition lights remain on.
I've been noticing that when I push the clutch in, my pt almost does'nt want to start, unless it all the way to the floor. I thought it might be the clutch. Tonight it just plain did'nt start, and the ignition lights are staying on? I disconnected the battery. The car is tuned, low miles in great condition. I have an idea this is a typical malfunction, with the ignition switch and possibly in conjunction with the clutch , can someone please help me? Thanks a bundle, Conrad
Old 05 Nov 2012, 09:16 pm
Smile Re: pt wont start? ignition lights remain on.
I have worked on 2 PT cruser, I found on both cars, there is a stran is wire that runs along the rack n pinion the same wires that connect to the alternator. They are hard to see you have to follow the wires from the alternator and inspect them carefully make sure u pull back the wire harness to expose all the wires. they fall down just low enough that they rub along the rack n pinion or maybe it is called the inner and outer tie rods. you will see what I am talking about if you lay under the car i mean u have to be in the center to see what I am talking about. hope this helps
Car Wont start!! txgalant8 Tech & Performance Forum 6 06 Nov 2012 07:45 am
No lights no power wont start unless jumped coogrrr General PT Cruiser Discussions 10 22 Aug 2012 10:57 am
Need new ignition cylinder, if I keep old key will car still start? Smifo Tech & Performance Forum 7 28 Dec 2010 11:27 am
Aftermarket radio wont turn on and off with ignition Samson Sound and Security Forum 8 23 Jan 2010 12:09 am
Does not start (no ignition / electrics OK) - HELP!! aljimtom Tech & Performance Forum 6 30 Dec 2009 11:13 am
