Head and Cam Bolt Torque specs?
Old 05 Nov 2012, 08:48 pm
Exclamation Head and Cam Bolt Torque specs?
I am putting everything back on after replacing the head gasket. I was wondering what the Torque Specs and Sequences are for both the Head Bolts and Cam Bolts. I cant find it anywhere I am going to do it in the morning so if anyone can help tonight, I would appreciate it IMMENSELY!
ALMOST FORGOT! It is a 2005 2.4L DOHC TURBO engine.
Old 06 Nov 2012, 02:35 am
UptownSport's Avatar
Default Re: Head and Cam Bolt Torque specs?
lightly coated with engine oil.
(4) Tighten the cylinder head bolts in the sequence
shown in (Fig. 32). Using the 4 step torque-turn
method, tighten according to the following values:
First: All to 34 Nm (25 ft. lbs.)
Second: All to 68 Nm (50 ft. lbs.)
Third: All to 68 Nm (50 ft. lbs.)
CAUTION: Do not use a torque wrench for the
Fourth step.
Fourth: Turn all bolts an additional 1/4
Turn
pattern is center out.
Install bearing caps and
tighten M8 fasteners to 28 Nm (250 in. lbs.).
Tighten M6 fasteners to 12
Nm (105 in. lbs.)
Tags
cam bolt, head bolt, torque sequence
Timing Repair Project - Bolt Torque Specs bmw525it Tech & Performance Forum 6 06 Oct 2014 05:50 pm
Torque Specs UZ4PLAY Tech & Performance Forum 15 02 Aug 2012 12:30 pm
Torque specs hidinginparadise General Turbo Discussions 1 19 May 2011 02:32 pm
torque specs gokart Tech & Performance Forum 2 15 Apr 2009 01:46 pm
bolt torque specs?? GTCruiser2003 General Turbo Discussions 1 30 Mar 2004 04:33 pm
