2009 pt Cooling fan has me perplexed
Old 07 Nov 2012, 10:49 pm
Default 2009 pt Cooling fan has me perplexed
So I bought a new 2009 pt cruiser from the dealer. I already put 65k on it...
The radiator fan crapped out on me and I ordered the replacement and took a look at the part before ripping the old one out...
Weird thing is the plug for the fan is the three prong connection and not the four prong that came with part. I'm confused because it supposed to four... Ahhh!
Any ideas?
Old 07 Nov 2012, 11:21 pm
cruserdad1976's Avatar
Default Re: 2009 pt Cooling fan has me perplexed
return it for the right part
Old 08 Nov 2012, 08:23 am
Ray_Dockrey's Avatar
Does you new fan have the relays on the side? If it does then you have the correct part.
Old 08 Nov 2012, 10:34 am
yes the relays are on the side but my fan has the three prong plug. 2009's are supposed to have a four prong plug. whats wrong here?
Old 08 Nov 2012, 10:39 am
The fan on the car actually has two plugs. The fan itself plugs into a harness that runs over to the relays and then runs to another plug down underneath which is the four pin plug. It is down there sitting right beside the transmission pan. My replacement fan which was a Dorman did not have that plug for the fan. It was all one sealed wiring harness with just the four pin plug. You have to remember that in the 06's and up they went to the Canbus system. So a majority of the electrical components have an extra wire which is the bus wire. That wire runs to the TIPM and monitors the electrical circuit. If the TIPM doesn't get the right signal from that component it will shut that circuit down until it is repaired.
Old 08 Nov 2012, 12:58 pm
i got the same fan.
so the three prong plug isnt used? just plug in the four prong plug and im good to go since its all wired together?
Old 08 Nov 2012, 03:00 pm
Yeah it is very confusing until you take the old fan out and compare the two. If you get it up on ramps and crawl underneath it you will see that square four pin plug. There was enough wire to take the fan out the top and then unplug that four pin plug. Not a whole lot of room to unplug it from underneath.
Old 08 Nov 2012, 03:15 pm
sweet! thanks a lot. i had a pretty good idea of how to do the job, but that was a slight curve ball. thanks for clearing it up. huge help!
Old 04 Jul 2015, 11:55 am
Can someone post pics of the 2 connectors and a wiring diagram.
Old 04 Jul 2015, 12:50 pm
The second generation (2006-2010) has the 4 pin grey plug that plugs into the wire harness coming from the engine.
If you ordered your radiator fan from a automotive parts store sometimes they give us the wrong radiator fan with the 3 prong plug for a 1st generation. This happen to me a few years ago with Rockauto. They immediately replaced it but in the meantime you have a PT Cruiser with no cooling fan. I ordered another one and keep it in the garage.
four prong plug dorman radiator fan - Bing Images
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
My 2009 Cruiser Ray_Dockrey Members PT Project 5 24 Aug 2012 12:51 pm
2009 pt oil type? IATA Tech & Performance Forum 10 22 Jun 2011 09:37 pm
230 hp 2006-2009 PT mangopuppy3 Classifieds: For Sale/Trade 0 11 May 2011 08:33 pm
