Smell antifreeze through heater.
Old 08 Nov 2012, 11:24 pm
Question Smell antifreeze through heater.
I have a 2003 PT that I got at the beginning of the year and now every once and a while I smell antifreeze when I turn on the heater. Did some investigation and thought it could be the heater core but the passenger floor is dry and the smell isn't consistent. It takes about a week for the reserve to empty so it's a slow leak. Could it be the water pump?
Old 08 Nov 2012, 11:44 pm
Default Re: Smell antifreeze through heater.
couldn't say one way or another. mine has been doing just that since i bought the car over a year ago. i personally think it's the heater core. maybe next spring i'll take the whole dash out and replace it. if that doesn't do the trick, i'll wait until i get closer to 100,000 miles and take it in for the timing belt, water pump and tensioner. i'm sitting at 84,000 miles now.
Old 09 Nov 2012, 04:49 am
Under hood leaks can carry in on the vent system. I would look at the cap, tstat housing and radiator. In that order.
Old 09 Nov 2012, 11:41 am
i agree. but mine only smells when i turn the dial to heat. if it was coming from a leaky source under the hood, wouldn't the antifreeze smell be constant?
Old 09 Nov 2012, 01:54 pm
Could be a small leak where the hose connect to the core. If you were so lucky. I would certainly rule the under hood out first. If not out there then you might unfortunately be right.
There are a few alternative solutions. If the system is clean and fluid is clean. These block seal products do in fact work. The easier one made by Bars leak, costs about $30 bucks don't go cheapest here. A half a bottle is all you need. Poor directly in the cap or pull a hose and put in that way. Run for 30 min with heater on and your done. Have not had any side affects in over a year. The other types require the removal of antifreeze and a drawn out process. A friend went that rout and even drove 4 hours away and back still no problems at over a year.
Old 09 Nov 2012, 05:37 pm
mine did that last year. i never bothered with it, and after not using the heat all summer, it seems to have miraculously fixed itself.
Old 24 Nov 2012, 09:43 pm
Has anyone found out what the cause is?? I am having same exact issue. Only when I turn dial to heat. Heater core looks like a bear to get to to check it out.
Thanks for any updates! Paul Cruser (yes, it's really my name!)
Old 04 Jan 2013, 05:42 pm
Hey hello ,
I have a used o6 but in excellent shape low miles convert, but a smell comes from the heater vents , like carbon dixocide but when I push the inside vent to cycle air from the inside it stops and never comes back, button off the smell returns ,
shoot my gal says eiouuuuu!
Old 04 Jan 2013, 06:35 pm
i read that like 5 times. are you saying it smells like exhaust? or coolant?
Tags
coolant, heater core, leak, water pump
Heater smell discovering06 Tech & Performance Forum 5 23 Dec 2016 12:31 pm
Gasoline Smell coming in Heater Vents 2002 PT Limited MarcusO Tech & Performance Forum 13 18 Jan 2016 01:05 pm
Foul smell when turn heater on 06 pt kkrtype General PT Cruiser Discussions 8 03 Dec 2013 04:38 pm
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
antifreeze smell????????? imjacked33 General PT Cruiser Discussions 6 28 Nov 2003 04:36 pm
