2001 cooling fan runs only with heater on
Old 10 Nov 2012, 10:26 am
Default 2001 cooling fan runs only with heater on
Hi.
I just replaced radiator ..thermostat..and car overheated still..i checked fan and it only comes on with heater/defroster.... and when I turn heater off ..fan goes off.... is it supposed to do that..the cooling fan ?????...any ideas... could it be the ETC? ..relay???... thanks..Bill
Old 10 Nov 2012, 10:50 am
Default Re: 2001 cooling fan runs only with heater on
Check to see if both speeds on the fan are working.
Old 10 Nov 2012, 12:10 pm
Yes, the fan should come on when your in the defrost mode as the compressor is activated and whenever that happen the fan comes on. It should also come on with the A/C as , like above, the compressor is activated. 90% of the time, overheating problems are because the fan has burnt out on one speed or the other.
How to test my radiator fan?
Old 10 Nov 2012, 12:13 pm
busted's right. the reason it comes on with the defrost is the air confitioner is on in defrost mode. and when the air conditioner's on, one speed of the radiator fan is always on. when you do decide to replace the radiator fan, get a dorman. you can find them on rockauto for cheap and they come with a lifetime warranty.
edit: and once again i'm late to the party.
Tags
cooling fan..relays..etc
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
2001 chrysler pt cruiser ran out of gas runs poorly PTCommuter Tech & Performance Forum 20 04 Aug 2012 01:31 pm
2001 fuel pump runs continuously stipedout Tech & Performance Forum 9 19 Sep 2011 10:34 pm
2001 & 2005 cooling fan issue ptcruiserdad Tech & Performance Forum 12 03 Jul 2011 07:26 pm
2001 PT - Starts, runs, stalls...won't start silver7 Tech & Performance Forum 12 20 Sep 2010 03:11 pm
