Engine light flashing
Like Tree3Likes
  • 1 Post By CREWZIN
  • 2 Post By rob342
Old 10 Nov 2012, 03:33 pm
HarleyTom's Avatar
Send a message via AIM to HarleyTom
Default Engine light flashing
Got off work late and was in the low 30's, went to start 04 PT cruiser and wouldn't start, engine was turning over good the battery was not sounding low charge, but not starting. I waited a few minutes and then started, driving home the check engine light was flashing and it started missing if I gave gas such RPM over 2000+. Got home ok at idle sounded like missing but smooth out when I gave gas, Ishut off engine and restarted to see if it would start, yes and then no misses but light still on.,, I did replace cam senor about 3,000 mile ago,, could it be going out again? or something else?
Hope to hear from someone......
Old 10 Nov 2012, 04:17 pm
Default Re: Engine light flashing
did you replace the cam sensor with a genuine mopar? if not, chances are you need a new one. pt's don't like non chrysler sensors.
Old 10 Nov 2012, 04:35 pm
First, did you do the key dance to see if there where any fault codes stored in the computer?
How to retrieve fault codes.
Second, I know you wanted to get home but when the engine light flashes, it's not a good sign. Staying lit means there's a fault code stored in the computer. The light flashes to alert to serious conditions that could lead to immediate loss of power or severe CAT damage. The vehicle should be serviced ASAP if this occurs.
That's from the Owners Manual.
Busted_PT likes this.
Old 10 Nov 2012, 04:43 pm
HarleyTom's Avatar
yes I did replace cam senor with after market part, and I did mopar key test just now here is what I have:
0442/ 0522/ 0335/0300
and oil light is staying on it was a little low on oil I topped it off but,
still hard starting,
little miss at idle
oil light still on
miss at about 2200 rpm
oh engine light still on to...
thanks for your replys too.....
Old 10 Nov 2012, 05:39 pm
Originally Posted by CREWZIN View Post
severe CAT damage.
we have a code for that?
Old 10 Nov 2012, 06:29 pm
You have a evap code miss code oil sensor code and a crank sensor code. Replace the oil sensor. These go bad. Check you vacuum lines start with the big ones first. Has any body been under the hood doing any work or anything? This could be some of the evap stuff. Also may be causing the miss. Just have to address one thing at a time.
Old 12 Nov 2012, 10:56 am
Stop starting your engine. A flashing check enging light, and an oil light can both be very serious. Follow the advice you're being given.
Hopefully this is just a case of a couple bad sensors, but if not, you could be doing serious damage to your engine. Don't start it until you know what the problem is.
Never run an engine with the check engine light flashing, and certainly not when the oil light is on, unless you know for sure that there is adequate oil pressure.
-Chris
Check Engine light flashing, PT stalling cherrytat Tech & Performance Forum 9 21 Nov 2016 05:45 pm
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Engine light flashing ptguy69 Tech & Performance Forum 3 09 Oct 2010 09:08 am
02 PT check engine light is flashing? PTkimmy Tech & Performance Forum 6 31 Aug 2010 02:36 pm
Check Engine Light Flashing on acceleration watkipk General Turbo Discussions 10 05 Dec 2009 10:24 am
