Overheat issue
Old 11 Nov 2012, 09:11 am
Default Overheat issue
I have seen alot of overheat issues on the thread and each case is diffrent. so will ask my question. 2003 PT with 2.4 Non Turbo am having an overheat issue. Fans work New Thermostat and Rad Cap. No Leaks Present but overheats and there is No Heat coming in and no coolant running. So i take it might be the Dreaded Water pump. Should i look for any thing else before i start that daunting task? Thanks for any help its appricated.
Old 11 Nov 2012, 09:48 am
Default Re: Overheat issue
Does it overheat while moving or when you come to a stop? How do you know both speeds of the fan are working? Is the radiator and overflow tank filled to the correct levels and was the system burped for excess trapped air?
Old 11 Nov 2012, 12:02 pm
yes both areas are full and fans are running on high. overheats when stopped and moving.
Old 11 Nov 2012, 12:09 pm
You might have a cracked head gasket. Loosing ANY coolant? Any signs of milky fluid in the oil (pull the dipstick)?
Old 11 Nov 2012, 02:26 pm
Just had this issue with my '03 Cruiser. Thank God it wasn't the head gasket. I replaced the thermostat, and flushed the radiator and replaced my old coolant with HOAT and distilled water.
It's either going to be head gasket, thermostat, water pump, or radiator. Now you have to go through the process of elimination.
Old 11 Nov 2012, 02:36 pm
eh, nevermind, I see you replaced the thermostat
Old 11 Nov 2012, 02:49 pm
If it turns out to be your thermostat, go to a dealer to get the Mopar part. Don't get an after market one. It's gonna be about $30-$40.
Flushing the radiator out isn't a hard thing to do. You can get the Prestone Flush and just follow the directions on the bottle. It's going to be an all day project, so start it in the morning if you want to save daylight.
The radiator plug is on the front driver side of the car (just under the front end). There's a diagram in the Haynes manual. If you don't own one, I think there is a copy available here on the forum.
If you're keeping water in your system, and you are over heating with your gauge telling you that your overheating, then it's probably going to be the water pump.
You should still do a radiator flush and add HOAT to your radiator. It will pay off in the long run!
How not to fix an overheat problem!! 767skyking Tech & Performance Forum 16 07 Aug 2012 04:12 pm
2002 Overheat Issue surfib Tech & Performance Forum 3 27 Dec 2011 09:10 pm
Another Overheat PT PTJohn Tech & Performance Forum 4 15 Sep 2011 12:53 pm
fan doesn't work but doesn't overheat 4SPEED General Turbo Discussions 3 07 Nov 2009 10:20 am
overheat onyx pt General Turbo Discussions 11 27 Nov 2006 10:55 am
