Horn honks too long
Old 11 Nov 2012, 11:55 pm
Default Horn honks too long
I know this sounds like a weird question, and not sure this is the right forum for it, but here goes;
I've noticed that on the rare occasion that I use my horn, even with just a quick touch, it honks for 4 or 5 seconds, way longer than I would usually prefer. (Or to put it another way, the horn keeps honking long after I've removed my hand...
Is there a way to adjust the honking duration, or is it possible that somehow my horn is sticking?
'07 Black PT Cruiser, Touring model & '75 faux-woody VW Beetle .
Old 12 Nov 2012, 06:08 am
Default Re: Horn honks too long
You probably have something sticking in the steering wheel. That's where the horn button controls are.
Old 12 Nov 2012, 09:07 am
Thanks Crewzin! So I guess I have to take the steering wheel off? From the diagram you so kindly posted, it looks like the bolt is underneath the Chrysler wing decal in the center of the wheel? I guess I need to peel this off to remove the wheel?
Old 12 Nov 2012, 09:14 am
Ray_Dockrey's Avatar
Actually you have to pull the airbag off. The horn mechanism is behind the airbag. You do not have to remove the steering wheel. And being that yours is a 2007 it will look different then the image above. I found a thread that shows the 06 and up assembly.
07 Remvoal of Horn button/cover
Old 12 Nov 2012, 10:08 am
Disconnect battery before attempting this!
Old 12 Nov 2012, 10:13 am
That info was in the link I posted lol plus I thought I would save him from pulling off the Chrysler emblem and being disappointed but I guess I should have mentioned disconnection the battery first lol.
The whole process isn't that hard. I had to take mine off my 09 to install the factory cruise and other then working blind trying to unhook the clips that hold the airbag on it is pretty easy.
The main thing like said above is disconnect the negative and move the cable somewhere it cant touch anything. Then hit the brakes a few times to rid of any residual power and I waited an extra 15 minutes before starting.
Old 12 Nov 2012, 10:26 am
2step's Avatar
I haven't actually seen the "switch" that's on top of the airbag stack, under the steering wheel trim in a Cruiser, but usually it will be some sort of curved or domed spring steel that can snap down to make make contact and complete a circuit while being pressed, then when released will snap back breaking contact. It should be nothing more than a waffer thin, momentary switch that's pressed and released. If the horn is continuing on after you let off, something is binding or delaying or the tension in the spring steel is failing.
I haven't had your problem with the extra delay but once on another vehicle, I mashed the horn button hard in a traffic situation and had the horn remain on so that I had to get under the bumper and pull the wire to disconnect the horn. A week later when I got the time to figure it all out, I reconnected the horn and the problem had cured itself. In my case, it was me mashing beyon what the horn engineers had designed for but in your case maybe the switch is wearing out or failing some other way.
Old 12 Nov 2012, 09:28 pm
Thanks for all the suggestions! Looking forward to being able to tap out morse code on my horn, instead of just dashes Also looking forward to avoiding airbag-face
Tags
honking, horn
Been gone too long Busa_Powered General PT Cruiser Discussions 0 28 Apr 2012 09:32 am
How long? harrym General PT Cruiser Discussions 17 21 Jan 2012 10:04 pm
2002 PT Cruiser horn honks on ignition mikenguy General PT Cruiser Discussions 0 17 Oct 2010 06:25 pm
HELP - horn honks all the time PatJ General PT Cruiser Discussions 4 25 Jan 2009 09:10 am
It's a long, long drive to Germany... Ed Lim Exterior Accessories Forum 0 05 Jun 2003 03:33 am
