P0304 cylinder 4 misfire
Old 16 Nov 2012, 04:18 pm
Default P0304 cylinder 4 misfire
A couple of weeks ago, I develop a miss at idle in my '08 Cruiser. After checking/replacing the usual suspects, I am a bit confused about what my next steps should be. I replaced the plugs (Bosch Platinum) and the wires (Bosch, too), replaced the upper intake gaskets, I changed out the battery for an Interstate 5 year (routine maintenance) added a bottle of injector cleaner to the fuel system, and yesterday I ran a can of Mopar combustion chamber cleaner through the intake system. The cleaner helped a little, but the light is back on again. The car runs fine at speed, and gas mileage has not changed. I can't feel a miss at RPM's over idle. One other thing - the alternator seems to be acting up a little bit. The lights get brighter and dimmer occasionally, and a couple of times the belt started squealing at idle - like the alternator was siezing a bit. I am going to swap it out, but I don't believe it is related to the misfire. I am thinking injectors, coil, or burnt valve. Anybody have any ideas? BTW - 2.4L non turbo, 90K miles.
Old 16 Nov 2012, 04:24 pm
Default Re: P0304 cylinder 4 misfire
Adjust the belt might be loose. Low voltage will cause some funny things. Check and see if you have any cracks in the coil.
Old 16 Nov 2012, 04:52 pm
Try swapping plug & wire from 4 with another cylinder - to rule out a bad wire/plug.
Old 16 Nov 2012, 08:07 pm
Normally that would be good but He has already replaced both with new. But moving an injector would be something to try. A cylinder compression and leak down test might also be considered before spending more money.
Old 17 Nov 2012, 04:15 am
Thanks, Busted - I think a leakdown test makes the most sense at this point. Gotta find some time to do it. I read somewhere that #4 cylinder tends to carbon up quicker than the other 3 cylinders. I might try 1 more can of CCC anyways. Will keep you posted.
Error Code P0304 Cylinder 4 Misfire Detected WV05Cruiser Tech & Performance Forum 16 23 Feb 2016 10:33 am
P0304 misfire sporttraveler Tech & Performance Forum 2 20 May 2012 07:19 pm
p0304 misfire code sporttraveler Tech & Performance Forum 9 17 Feb 2012 08:26 pm
Misfire In Cylinder 4 shoe989 Tech & Performance Forum 13 23 Feb 2011 03:56 pm
Compression; Continuation of P0304 Misfire duffner Turbo Performance 3 09 Apr 2010 12:39 pm
