PT Cruiser died no fuel and won't crank!
Old 17 Nov 2012, 12:13 pm
Send a message via AIM to PurpleCruizerConvertible Send a message via MSN to PurpleCruizerConvertible Send a message via Yahoo to PurpleCruizerConvertible
Default PT Cruiser died no fuel and won't crank!
I have a 2005 PT Cruiser GT Convertible with the 2.4L HO motor. My wife and I were driving thru town and we slowed down the engine died and we pulled over to the curb. I tried to re-start it thinking it just stalled but it won't crank and it's not getting fuel. it has a full tank of fuel. We have plenty of electicity as the battery is only 6 months old. We tried to jump start it and that didn't work. Could it be the decelerate fuel cut-off relay or just a bad fuel pump? The engine will not crank! Thanks for any help you can give me.
Old 17 Nov 2012, 12:49 pm
Default Re: PT Cruiser died no fuel and won't crank!
listen under the car and see if you can hear the fuel pump prime when you cycle the key
do the headlights work?
how many miles?
what is the condition of the battery cables? mine corroded in half by the starter
does it click like a low battery when you try to crank it?
turn the key on off on off on and read the codes it displays in the odometer
let us know what you find.
If it won't crank over at all, many owners have had problems with the ignition switch.
Old 17 Nov 2012, 04:47 pm
Here are the codes that come when I cycle the key. FL007 EE 14 BL 01 It doesn't prime the fuel pump and will not click when you try to start it. I only have 38,000 miles on it the cables are in good shape. Tried resetting the ECU by holding in the trip reset button and turning the ignition to the run position. It still won't start. Thanks.
Old 17 Nov 2012, 05:26 pm
i never have seen any codes like that. usually they are like "p0420" etc. -i'm sure someone more knowledgeable than me can point you in the right direction soon
Old 17 Nov 2012, 05:50 pm
Ray_Dockrey's Avatar
How did you get that code? That code looked familiar so i looked it up and that is the software version of the PCM. It usually shows when doing the instrument panel self test.
Old 17 Nov 2012, 06:55 pm
Ray's right, they aren't the fault codes only software codes. It means you didn't do the "key trick" correctly. Try again.
How to retrieve fault codes.
Old 17 Nov 2012, 07:00 pm
Okay, looks like I didn't do it enough times. I think I only did it 2 times before I left it in the on position. I'll try it again tomorrow. Thanks for all the input!
Old 18 Nov 2012, 08:19 pm
Tried the key trick today no codes appeared. But the airbag light stays lit does this mean it thinks the airbags deployed when they didn't actually deploy. Could the deceleration fuel cut-off relay have quit and caused the fuel pump to not work? Any ideas would help. Thanks
Old 21 Nov 2012, 05:03 pm
Had it in the shop. Turns out the ECM is bad had to replace it. New computer and flash software and shop time just under $1000. Ough!!!!!
2001 Cruiser Limited - NO CRANK!! panjammer Tech & Performance Forum 12 20 Oct 2012 04:49 pm
02 Cruiser, won't crank ohwell Tech & Performance Forum 5 27 Jun 2012 09:14 pm
fuel regulator changed-car died chaparra626 General PT Cruiser Discussions 1 13 Jun 2011 12:06 pm
02 pt cruiser won't crank over. vanhalen7174 Tech & Performance Forum 2 04 Apr 2010 12:06 pm
02 pt died and won't crank over ronwins3 Tech & Performance Forum 16 23 Dec 2009 06:25 am
