Stripped thread
  • 1 Post By CREWZIN
Old 18 Nov 2012, 07:22 am
Stempy's Avatar
Default Stripped thread
Today I have attempted to do an oil change for the first time since owning my PT. To my horror, When I tried to remove the sump drain bolt it kind of cracked then just spun. I managed to get it out but it seems a previous owner had stripped the thread and just glued the bolt back in.
Being as it's Sunday there's not a lot I can do about it today, but do you think it would be possible to have the thread in the sump repaired or am I looking at having to buy a new sump?
2004 PT Cruiser Limited 2.4L
Old 18 Nov 2012, 08:09 am
Default Re: Stripped thread
Some things to read:
Oil pan drain bolt
Oil pan plug
http://www.mtsac.edu/~cliff/storage/...lug-Repair.pdf
How do I fix a stripped engine oil drain plug thread? - Hot Rod Forum : Hotrodders Bulletin Board
Old 18 Nov 2012, 12:22 pm
Stempy's Avatar
Wow! thanks, I didn't know there could be so much information on stripped threads.
Old 18 Nov 2012, 01:05 pm
Whatever you do, plan to do or have done, there's always people that have done it before you and will be doing it after you. You only have to know where to look.
New famous quote by "CREWZIN".
Badglas likes this.
New to Thread cdub Welcome New PT Cruiser Members 13 08 Aug 2011 03:03 pm
STRIPPED SPARK PLUG HOLE chuck2112 Tech & Performance Forum 5 01 Mar 2010 09:52 pm
Spark plug threads stripped in head. What are my options? WalterZoomie Tech & Performance Forum 6 12 Nov 2009 03:45 pm
Accessory Drive Splash Shiel Bolts Stripped ottoman Tech & Performance Forum 2 23 Mar 2009 09:41 am
Stripped a thread while installing my starter RainyTX Tech & Performance Forum 1 08 Jan 2009 08:34 pm
